Is this repair manual + diagnostic kit off E-bay good?
. Quite a lot more than the manual on disc.I just thought of something that's critical for you to use the manual on disc. I don't think the eBay listing mentions it. In order for this sucker to install correctly, you need 1) Vista, 2) 25 GB+ available storage, 3) a dual-layer CD-ROM drive w/ latest drivers, 4) late version of Java, 5) Internet Explorer. Definitely let us know if you have problems w/ the install. It comes w/ very detailed documentation. The problem is that the details are sometimes wrong and require interpretation/guessing. Also encountered at least one undocumented problem, which was solved by running it as the administrator. Anyway, give it a shot!
Will this solve my problems:
09/2009
English/Chinese/Deutsch/French/Italian/Korean/Spanish/
Portuguese/Finnish/Danish/Japan/Swedish
Function:
1.1989~up to now Car, Bus, Truck, Sprint, Smart ;
2.All electric system Diagnostic;(Do not include flash code)
3.Reading out and erasing trouble code;
reading the real-time data of sensor and actuator;
testing the component of cars; coding and programming.
Character:
1. Realizes all the function of official factory BENZ compact 3.
2. C3 Multiplexer can connect to factory computer and IBM laptop.
3. Complete maintenance data. It could offer full disassembly and assembly circuit diagram, working principle and element place anytime needed. It is the best assistant for maintenance man.
Package Include :
1. MB C3 STAR MULTIPLEXER( Benz VCI)
2. 16 PIN OBD II cable (OBD Diagnostic Socket )
3. 38 PIN cable (Old Benz Round Socket )
4. 14 PIN cable (Sprint. Bus. Truck Round Socket)
5. 4 PIN cable (Old Benz Rectangle Socket)
6. RS232 Cable (Computer Communication)
7. DAS Sofware with HDD (For IBM T30)
Software Version: 09/2009 (All Languages avaliable)
Product software includes :
DAS : the automatically Diagnosis Assistance System
WIS.net : Workshop Information System
EPC.net : Electronic Parts Catalog
ST finder2009 : Part location finder
STARUTILITIES : the movement management system and self-test
SD Media: Video and PDF lessons
Be careful guys...
a mind meld with your car's sensors, allows interrogation and provides you
tweaking capability with nearly all the settings possible (about the same as
that available at the MB dealer)
