SL55 190mm crank pulley VS E55
C218 CLS63TT PP Edition1, W213 E63S
here is a video between SL55 & E55
upgrades are:
SL55:2006
- 190mm crank pulley package ( includes Waterpump, etc ) pulleis
- K&N filters
- ECU tuning
E55:2003 ( runing on the with this pulley since 2 years )
- 190mm crank pulley, etc
- LT headers
- Cam shaft
- Larger H/E
- ECU tuning ( dont think it is a good one ) lo0ol
http://www.youtube.com/watch?v=fKWAOXi54RQ
upgrades are:
SL55:2006
- K&N filters
- ECU tuning
- LT headers
- Cam shaft
- Larger H/E
not my car. none of them
the E55 was the strongest here, since 2 years no one could beat him @@
but the sl owner ( my friend )finally installed this large pulley.
it was just to beat that guy. nothing more. lol
but the IAT increases like hell when he hit it hard.
after reaching 220, u can feel the car is slower and not pulling hard.
i pass by him with my pulley @ about 260. although i have other mods that boost my power a bit.
but it is a sign for others. that it is safe to use the 190mm. because the E55 owner had it installed since 2 years and it was made here in UAE/ Dubai, the only problem with the E55 pulley that it is one piece ( doesnt has the rubber thing to obsorve the shocks ).
but the SL owner got his from germany and it looks like stock but larger. we measered it and it is from side to side 190.4mm
the same company makes also 205mm, but getting bigger injectors are a must and it is for drag racing as they said.
the SL from germany ( online )
and the E is a shop here localy ( his tuning is well known a **** one ) but some of the guys here like it becaise it is cheap.
although he only has one or two files and he just load them to any car.
CLS55 AMG 030
Hey any info on this MB http://www.youtube.com/watch?v=D4gDV...eature=related
it increase the boost of the supercharger and makes it spin faster ^_^ this is the main job.
to make more air goes into the engine. which leads into faster burning and more power.
Brabus K8 E55 05
3allawy,
Is it only one part or set of parts? are there different brands?
For the Brabus 05, will it be the same as AMG 05? if it makes some different, then diffidently i am thinking of one because this Audi RS6 scare me every time i see it next to our building
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
if your car is K8 brabus, then why are you afraid ? !!!!!!
you will smoke him easy.
pulley is a part
but you should change atleast 3 pulleys with it.
if your car doeasnt has one
pulley is a part
E55 2003, C32 2002,
Ali, what is name of this German modifier? where your friend got this is size pulley from
This Cam shaft in the E55 , is it made locally also?
E55:stock
C32:
LET intake with ITG Filter
Eurocharged short Headers
LET 185mm Pulley
LET Tune
C3P HE
CM30 Pump
Resonator & Rear Cat Delete.
NGK IX Iridiums
Magnecor 8.5mm Wires
E55:stock
C32:
LET 185mm Pulley
LET Tune
C3P HE
CM30 Pump
NGK IX Iridiums
PLATINUM SPONSOR
I know the crossfire guys have all this calculated for the 6 banger MB S/C but have not seen much on ours.. They even listed the specs from the Japanese MFG of our S/C..
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
2003 E55 & 2014 GL550
205MM????
That is just unreal. Can you guys imagine how tiny that water pump pulley must be. Bet the water pump is spinning at like 25,000rpms![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
I dunno man, even AMG's chief said that the supercharger can only flow so much, then she just can't push anymore for the amount of heat returned.
I know the whole world isn't 1/4 mile happy like we are in the US, but any 1/4 mile times on the 190 or 205mms over there?
I thought I was bad a$$ running a 185mm custom made, but I run it up at 4500ft elevation with DA's in the 6-7K range in the summer.
Thanks for sharing this info Ali!!
PLATINUM SPONSOR
All the 190mm pulley`s I have seen come with a stepped water pump pulley (clear the large S/C pulley section) So WP, turns stock RPM..
