- Mercedes-Benz C-Class AMG: Why Does My Battery Keep Dying?
Guide to diagnose trouble and recommended solutions
Browse all: Electrical Guides
Battery keeps dying!!
I removed the main battery negative and put multi meter in series (from neg post to cable) it read 11.6v, i thought maybe bcm faulty so put meter from battery post to chassis, still 11.6v. I put car to sleep locking all door latches waiting half hour then removed main battery neg terminal then put multi meter in series again and pulled each fuse one by one looking at meter each time for drop, nothing. i pulled every fuse on car on all 3 fuse boxes one by one, each time checking meter, still sat at 11.6v. I then reconnected battery and tested each fuse with meter, none had any reading (0,1 / 0,0) . I then did a continuity test on all the relays, all good.
I re charged the battery, started the car put on heater, stereo, window heaters, lights and tested the main battery to see of it was charging ok, all seemed good, was getting 13,5 to 14,1v which leads me to believe alternator and regulator ok and charging battery correctly.
All these tests were over the last 3 days and charging and discharging the main battery so many times has ruined the battery, now it says its fully charged but when i put it on car it barely turns it over. So i had to go and buy a new battery today, but i'm still getting the crazy 11.6v drain. What would be using that much power ??. I disconnected all the fuses that run the (aftermarket) stereo, still drain, and i disconnected the seat control module, still drain. I'm now thinking about removing ALL the fuses in the car, see if the drain drops, then replace them one by one to see when it reappears.
I've had the car 4 years and this has just suddenly happened, oddly enough the day i was replacing the blown fuses.
Here's my situation: We have a 2003 S500 4matic with some sort of parasitic battery drain...it keeps draining down the battery after a couple of weeks of not being run. Neither a Battery Tender nor a Duracell equivalent can prevent this from happening. When it does, I must disconnect the battery and use a 10amp charger to charge it up again--this is at least the 3rd battery in the car. My eldest son used to use it, but when he went off to college it didn't get driven as much.
Several years ago, the radio/entertainment/phone head went bad. An audio shop installed an Alpine head to replace it that handles radio, CDs, Blue Tooth, Pandora, backup camera, hands-free calling, and Nav. As long as the car was driven regularly there appeared to be no problem.
I have had the car to two separate shops that specialize in European cars and all sorts of higher end vehicles. One was actually formerly a certified Mercedes mechanic! Neither could find the parasitic leak.
I have 3 possible culprits that I know of:
1) Something you said about the MOST module makes me wonder if it's continually hunting for its own Mercedes components, draining power at unobserved times. The CD changer is still in the trunk, and the phone mount is still in the center console. I have no idea where the Nav unit is...but the head is on the floor in a corner of my garage.
Can the MOST module be removed or power cut to is because it no longer, as far as I can tell, doing ANYTHING useful that the Alpine head isn't?
2) A recent failure that I didn't know about until a couple of days ago was the Driver's Door Control Module. AFAIK, it was fine but when the 2nd shop picked it up (I wasn't home) the driver couldn't adjust the mirrors, seat, seat heater, etc. I tested the Brown and Red/Black wires, pins 1 and 2 and directed and there was no resistance to ground from the Brown wire and 12v from the Red/Black one, indicating that the DCM is probably bad--I have a used one on order. I gather that, too can be the source of a parasitic drain.
3) The air suspension system has a slow leak and, even when the car starts after a week or 2, the suspension is at the bottom with warning not to drive. It pumps up quickly and stays up....But can THAT be the source of the leak as well?
This has been such a great and comfortable car, reliable, powerful, and sure-footed, it seems a shame to have to trade it in because this drain cannot be found. And I simply do not trust Mercedes dealerships with cars out of warranty not to run up the bill far beyond the book value of the vehicle...one dealer tried to do that on an old ML500 we had--the estimate was nearly DOUBLE the SUV's book value! Things they priced at thousands (PS pump, rear brake rotors and pads) I did for a few hundred in parts.
Thanks for any help you can give me!
Yes the MOST can be disconnected. You will need a connector to bypass all modules, or the ones you dont use. Your Nav, Phone, Amp, Teleaid are all inter looped on the MOST system.
The battery has been checked in the last several days. It's fine.
I don't want to fix the MOST system or diagnose which components need to be replaced. I want to disable it because ALL the components in it are no longer usable as the Alpine head unit has replaced all of its functions.
But thanks for trying to help.
I've been hunting and have already had 2 specialty shops, including one which had a certified Mercedes technician, take it. Couldn't find the problem. Each had it for well over a month without being able to find the answer. As for the dealers, I do not trust any of the local Mercedes dealers. Most are now owned by Open Road, as are the local BMW dealers. I've spent hours and hours trying to trace the drain myself with no luck, and, basically, haven't been willing to trust this car to be reliable since before the Pandemic. At some point, as much as I love this car, enough is enough. It's just a car.
At some point the book value of the car, sadly, makes it not worth it. I'm sort of near the end. IF the DCM module fixes the problem of the driver's side window, mirrors, seat adjuster, seat heater/cooler and power door locks, I MAY ask a dealer to spend 2 hours solely on finding the leak, and nothing else. If they can't, we will have to trade it.
I already have issues leading me to want to get rid of the car.
BTW, the Driver DCM module I got off eBay seems to work perfectly but I still don't have power door locks or remote trunk opening.
