Will SL55 engine fit our cars?
Old Dec 31, 2009 | 10:18 PM
beauphus's Avatar
CLS55 & CL CK60
I found an engine to replace my hydro-locked engine but its an engine from an SL55 from LKQ (Potomac German Auto) with 21k miles. My mechanic tells me that the engine might not work because the SL uses ABC(?) suspension while ours uses air ride and the pumps are different therefore I would have a hard time making it work. Can anyone here confirm this or have any feedback?
The insurance company declared my car a total loss from the hydro-lock unless I can find a reasonably priced replacement engine. The rest of the car is perfect and I am trying desperately to keep it from being totalled.
Old Dec 31, 2009 | 10:21 PM
Fantasm's Avatar
Car Whore
Take the pump off your old car?
Old Dec 31, 2009 | 10:26 PM
beauphus's Avatar
CLS55 & CL CK60
Thats what i said however my mechanic says I would have to replace the front plate(?) or something of that nature. not really sure why it wouldnt work so I was hoping someone here could advise. A compatible engine with 21k miles would be IDEAL...
Old Jan 1, 2010 | 02:58 AM
blackbenzz's Avatar
haters crazy
It's basically the same engine. I don't see why any differences couldn't be swapped over
Old Jan 1, 2010 | 03:26 AM
Blue_Monster's Avatar
215
that engine will work
the abc has nothing to do with the engine
I would suggest to find a different mechanic
Old Jan 1, 2010 | 08:08 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
The AMG 55 engine will definitely work, Mercedes manufacturers these engine to fit in multiple platforms i.e. S55, SL55, E55, SLK55, G55, C55, although some 55 engines aren't supercharged, be aware of the that. it is my opinion that your mechanic isn't very knowledgeable, about various Mercedes.
Old Jan 1, 2010 | 10:16 AM
moparrbust's Avatar
2005 Crossfire SRT-6
x2 The bolt on accessories may vary from model to model..........but a 55k engine is a 55k engine.
Old Jan 1, 2010 | 10:28 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
The engine will work, you will have to use the engine mounts and oil pan from the old motor
Old Jan 1, 2010 | 02:39 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
+1000000000
Yup she'll work. AMG stamped um out like cookie cutters.
All the same cept for slight differences like mentioned above.
Old Jan 1, 2010 | 04:24 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
Agreed !
Old Jan 1, 2010 | 08:18 PM
beauphus's Avatar
CLS55 & CL CK60
checking for water damage. yikes
Attached Thumbnails Will SL55 engine fit our cars?-photo.jpg   Will SL55 engine fit our cars?-photo2.jpg
Old Jan 3, 2010 | 05:15 PM
Nait Sirhc's Avatar
2002 BMW M5, 1992 AWD DSM, 1988 Yamaha FZR1000
Did you try to go bass fishing in it like the Veyron guy?
Old Jan 4, 2010 | 12:48 AM
RenntechE55's Avatar
CLS55 AMG 030
Yes it will work I have a S55 engine in my E55 and I think it was only the oil pan and front timing case cover that had to be change IIRC.
Old Jan 4, 2010 | 01:10 AM
beauphus's Avatar
CLS55 & CL CK60
My mechanic said the timing case cover swap is the main issue with the conversion and it would take approx 15 hours. Does this seem accurate?
Old Jan 4, 2010 | 01:25 AM
SUNILP's Avatar
2015 E250D
I don't remember any change in the timing cover. I stuck a s55 engine in my w203 c class and everything works as from factory. Oil pan and pump are definitely different. Accessory components can we swapped over such as power steering pump, etc.
Old Jan 4, 2010 | 08:58 AM
CLS55 AMG 030
I'll have to check for you because I was told it had to be swapped but I think i remember him saying that it fit ok. I'll PM you when I find out for sure.
Old Jan 4, 2010 | 08:59 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
I guess you discounted my advise. Who is your mechanic?
15 hours for the total engine swap is about right.
15 hours for timing cover swap?
Here is more advise, spend a few dollars and get the information from the "horses mouth"
http://www.startekinfo.com/StarTek/
Old Jan 4, 2010 | 10:24 AM
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
I highly highly recommend you go to another mechanic.
