Best Drag Radials for the E55
Old 01-23-2010 | 02:37 PM
izzynyc's Avatar
2016 C63s
What are the best drag radials and sizes for the E55? BFG? Nitto? or MT's? I am reading up on the Nittos and kind of leaning towards them but would appreciate some input.
Old 01-23-2010 | 02:54 PM
bassn_07's Avatar
2006 E55 AMG
Are you looking for track specific DR's? If you are Hoosier in a 255 50 16 get my vote. I've tried MT Street radials 255 50 16, MT street radial II's in a 265 40 18, and the Hoosiers. Hoosier and the MT street radials are both very good drag tires but I found the Hoosiers to be more consistent. The track I race at is very slippery and DR's are a must for both good ET's and safety for cars like ours. My 60' times are very consistent right now ranging from 1.585 - 1.592 if track prep is decent. The only downfall I might see is that they'll wear faster than the MT's, me personally, I don't care as long as I trust them to stick when it counts.
Old 01-23-2010 | 04:19 PM
BenzoBoi's Avatar
Super Moderator
W221
I have only had experience with the MT Street readial II's in a 255/50/16 and they work GREAT! I've had a couple passes on them and they stick very well for me. 1.6's are no problem.
I'll be tryin the Hoosier's that bassn 07 is talkin about soon in a 255/50/16. I'll get back to you on them.
Old 01-23-2010 | 04:33 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
I have MT's now but I will give the hoosiers a shot next. My goal is to run 11.6x with stock power. I know it sounds but as the red neck said "you about to find out"
Old 01-23-2010 | 05:20 PM
izzynyc's Avatar
2016 C63s
I think I want to stick with the stock 18's on the drag radial and would like something I could use everyday not track specific.
izzynyc's Avatar
2016 C63s
What's your 60 foot with the MT's?
Old 01-23-2010 | 05:22 PM
izzynyc's Avatar
2016 C63s
What kind of 60 ft were the hoosier streets getting you?
Old 01-23-2010 | 05:44 PM
1.72 is my best so far, I have room for improvement and I may swap batteries and put skinnies up front.
Old 01-23-2010 | 05:53 PM
prodigymb's Avatar
997TT, R8 V10+, G550, Plaid S
for track or street racing?
track 255/50/16 MT is what I use now
for street drags i used 305/35/18 Nitto 555R
Old 01-23-2010 | 07:10 PM
320 dreamer's Avatar
2003 porsche 996 turbo
i have consistent 1.7 60 ft times with the nitto 555r's but am looking at the mt et streets for a better 60 ft time
i have a set of nittos on 17" amg reps for sale dirt cheap if you want to try something without spending a fortune
https://mbworld.org/forums/wheels-ti...-555r-drs.html
200 plus shipping
Old 01-23-2010 | 07:45 PM
izzynyc's Avatar
2016 C63s
Will those clear the brakes on an E55?
200 plus shipping
Old 01-23-2010 | 07:46 PM
izzynyc's Avatar
2016 C63s
How do you like the nitto 18's at the track? Did you run it with them on?
Old 01-23-2010 | 07:58 PM
prodigymb's Avatar
decent. 1.7x 60 foots
Old 01-23-2010 | 08:21 PM
i dont know . 17" rims with 35 et maybe someone can tell you if they will fit. i would guess if needed spacers would do the trick.
Old 01-23-2010 | 09:54 PM
bassn_07's Avatar
2006 E55 AMG
Ranging from 1.585 - 1.592 if track prep is decent. Right now I have over 10 10 second passes on my hoosiers. My best ET to date is a 10.776 with the 60' timer not registering that day . I'm sure that would have been my best time, oh well. I might have my CCW custom drag rims going up for sale soon which would come with MT Street Radials 255 50 16's. I'll let you guys know if I decide and first come first serve.
Old 01-24-2010 | 12:52 AM
I use 17" MB wheels with 275/40/17 MT's and the rims offset is 38
Old 01-24-2010 | 04:44 AM
so it looks like a 3mm spacer would be all thats needed if the 35 et isnt a direct fit.
let me know if you want the dr's. racin season is almost here!
Old 01-24-2010 | 12:02 PM
Craigo's Avatar
W211 E55K, Duc 848
This place needs help with wheel offset info... if he adds a 3MM spacer to a wheel with a 35 offset, it will now have an offset of 32... which makes it stick out further... the lower the offset the further away it should be from the hub... the higher the offset the more the wheel will be tucked...
Old 01-24-2010 | 12:21 PM
no help needed. if he is worried about the rims hitting the brakes the 3mm offset will push the rims away from the caliper.
Old 01-24-2010 | 01:06 PM
Craigo's Avatar
W211 E55K, Duc 848
I guess i misinterpreted the math in your post, and how you logically added a +3 to 35... instead of subtracting 3 from 35 to get an offset of 32...
Old 01-24-2010 | 01:15 PM
Craigo's Avatar
W211 E55K, Duc 848
^^ I'm not trying to come at you, i know it's hard to tell with tone with text... as we all know. I'm just trying to help you provide the correct information, maybe it'll help you sell your wheels a little easier...
Old 01-24-2010 | 01:23 PM
bassn_07's Avatar
2006 E55 AMG
Here's a calculator that might help make things a little easier. It takes both the current and new setup, also the width of both rims and gives you the offest needed to make the new one work.
http://www.1010tires.com/WheelOffsetCalculator.asp
Old 01-24-2010 | 04:16 PM
izzynyc's Avatar
2016 C63s
Thanks guys I appreciate the input.
Old 01-25-2010 | 02:49 PM
Lopes80's Avatar
E55 AMG
My local hoosier dealer is saying you cant use the tyre on the street, is this correct?
Paul
Old 01-26-2010 | 09:00 AM
Paul
the hoosiers are dot rated for the street class but not street legal. the mt et streets and nitto 555r's are dot rated and street legal. the mickey thompsons are legal but be warned the tread pattern is barely enough if you get caught in a storm. nittos are much better on the road but more tread pattern less track contact.
its a trade off
another consideration hoosiers weigh 22 lbs and mt et streets weigh 29 lbs. nittos were mounted when i got them so cant say
Quick Reply: Best Drag Radials for the E55
