Are you slammed? Do you rub? Wheel offset?
Old Jan 25, 2010 | 07:18 PM
AWOL's Avatar
e55
Im now officially slammed via my new technique. I rub with stock width tires and oem rims.
I think Im going 18" forgestar f14s soon, but now the question of offset. I want the rim to sit flush, so obviously it would rub more, hence I raise it a tad.
But, I do see some pretty slammed e55's out there and I was just curious of rim size/tire/offset combo and if you scrape hard.
only pic for reference right now:
sits about 24" from the top of fender to ground in the front, 24.5" in the rear.
Old Jan 25, 2010 | 07:22 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
IM DROPPED VIA RENNTECH MODULE WITH 19INCH MODULARES WITH 10 INCH WIDES IN BACK AND IM GOOD NO RUBBING . EVERY NOW AND THEN A HARD AZZ LAUNCH WILL CAUSE REAR TIRES TO RUB . BUT FOR THE MOST PART ITS ON THE MONEY
Old Jan 25, 2010 | 07:28 PM
AWOL's Avatar
e55
what about fronts, my front rub during a turn. rears are mint
Old Jan 25, 2010 | 07:39 PM
LADY_AMG's Avatar
E63 AMG & CLK350
Same here, but I am not slammed and I have 20s.
Old Jan 25, 2010 | 07:57 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
Fronts have no problem but i did have to change out a hub bearing , Realized the noise once lowering the car .
Old Jan 25, 2010 | 10:31 PM
beauphus's Avatar
CLS55 & CL CK60
i slammed using renntech with remote and i have 20X11 on rear and 20X9 front and i never rub unless i hit big bumps
Old Jan 25, 2010 | 10:42 PM
AWOL's Avatar
e55
what are your offsets?
Old Jan 25, 2010 | 11:01 PM
bnzuovr's Avatar
2004 W211 E55K, GL550
i was never rubbing after lowering the car but after my stupid accident now on turns over 15 20 miles if there is a bump in the road it rubs and so far had to get my fenders straighted out GRRRR
Old Jan 26, 2010 | 10:22 AM
jtc55's Avatar
08 E63
i'm running 20s and have no rubbing w/ front offset: 28mm and rear offset: 37 mm
Old Jan 26, 2010 | 02:22 PM
iceman-kimster's Avatar
2009 E63
Can you post a pic of your car with 20"s?
I haven't seen one with 20"s not lowerered... I want to see what it looks like.
Thanks.
Old Jan 27, 2010 | 01:36 PM
NSX2NV's Avatar
03' E55 Techtite Grey
I am slammed with 20's. Only rubbing issue is if I'm turning pretty hard going up a driveway or hitting a bump. I drive around town with pretty much no problems.
Old Jan 27, 2010 | 03:47 PM
AWOL's Avatar
e55
offset of 20s?
I want to have the wheels be flush as possible without rubbing at a considerably low height
Old Jan 27, 2010 | 05:35 PM
LADY_AMG's Avatar
E63 AMG & CLK350
Thanks.
Here ya go!
