Akebono ceramic pad install (nice!)
http://www.autopartsway.com/PartList.../pagenum1/tabS
Akebono EURO Ultra-Premium Brake Pads
Front - AKE1791714 $123.44
Rear - AKE1814169 $92.37
FREE SHIPPING
PS: Tirerack is the one that says "Not for track use" Not me.
I'll stick with my EBC pads for everyday use. REDS for the win!!
tem Description Price Qty. Total Mercedes Brake Pad Set Front (W215 W220 W230 W211 W219) - Akebono EUR983
SKU: EUR983 $129.99 1 $129.99 Mercedes Brake Pad Set Rear (W215 W220 W230 W211 W209 W171 W219) - Akebono EUR984
SKU: EUR984 $92.27 1 $92.27 Subtotal: $222.26 Coupon (SUMMER10) -$22.23 Shipping $0.00 Order Total: $200.03
http://www.fcpeuro.com/products/merc...11-w219-eur983
129.99 for fronts
http://www.fcpeuro.com/products/merc...71-w219-eur984
92.27 for rears
and then put in summer10 in the coupon code and get 10% off
shipping is free
total for fronts and rears shipped = $200.03
and Some shops will not turn drilled or slotted rotor due to cracking on the slots/holes after they are turned.
not worth busting a lathe to most shops so they will just tell you to get new rotors when it comes to drilled or slotted rotors... so if you are not getting new rotors then just replacing pads will work fine... (yeah i know you might have to change the pads after 45K miles instead of 60K)
I'd rather have a properly bedded pad than new pads that squeak on used rotors.
129.99 for fronts
92.27 for rears
shipping is free
I was able to use 10off99 to get $10 off and free shipping for a total @$212
WIS also seems unclear regarding replacement or reuse.
