Crusing Around in Mexico: E55 vs Viper
Brooke: That was a great baseline for the mods that are about to be installed! Much better than the M3 race.
http://www.youtube.com/watch?v=Cack_0w5O8g
I would never go from 20-30 in second gear.. To low of a rpm in second and to low in your power range.. Most any M5-M6 grear box will out gear you at that range..
50mph is a great roll speed in second.. That is what I hit your cousin`s STI with a few weeks ago..
You really need to get the widest Drag radials you can handle and take these cars from a dig or 15-20mph roll.
Never go against a worthy advocate outside your gear range.. 45-55 mph only or don`t race.. No matter how hard they want you too.. Find your spot from a dig and and know when you can handle a low mph roll and not spin much..
The Z06 has to be taken from a dig on hot drag radials and or at the track. The Vette has to be stock too and or a so/so driver..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
I need to find a pair of SLR rims for the rear!
as soon as you started to reel him in hard, he's braking like a queer passing ghey
parade. I'm certain his story/vidz on Viper forum made it look like you were never even close...
which usually gets followed up by a
