E55 Wheel Offset?
Old Feb 9, 2010 | 10:59 AM
bavboym3's Avatar
04 E55 AMG
E55 Wheel Offset?
Im looking for a new set of wheels, and I need to know the stock offset because I don't want to rub the fenders. My car has a rentech lowering module. Any recommendations?
Old Feb 9, 2010 | 11:02 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Offset for stock wheels is listed numerous times on MBW as well as listed in your owner's manual.
Old Feb 9, 2010 | 11:09 AM
930chas's Avatar
cornfed gtr and m3
I think stock is 30 front and 39 rear.
Old Feb 9, 2010 | 11:15 AM
bavboym3's Avatar
04 E55 AMG
I used the search feature, and couldn't weed through it to find out. I don't have my manual yet, and I want to know what the best offset is on lowered cars so it wont rub.
Old Feb 9, 2010 | 11:29 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Well, I can't comment on the E55, but the E55 and E63 are built on the same platform. I have aftermarket wheels on my E63, measuring 235/35-19 front with a 30 offset, and 275/30-19 rear with a 35 offset with no rubbing issues, and it is lowered via Star. Probably not to the extreme that your E55 is though.
Old Feb 9, 2010 | 11:32 AM
Yuille36's Avatar
I just now thought about this some more, I would suggest that you contact tirerack. Those guys seem to know allot about clearances as stuff, I called them when I bought tires, to ensure that i wouldn't have rubbing issues, and they assured me, that I wouldn't. And they were right on the money. Luke is whom I spoke to.
Old Feb 9, 2010 | 11:39 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
I know for fact front 8.5" (35mm) & Rear 10" (35mm) 19" or 20" will fit perfect even on lowered car with proper tire sizes of course.
Old Feb 9, 2010 | 02:38 PM
jangy's Avatar
2015 S212
Peter is about dead on, except that the rear likes to be closer to 40 for a 10 inch. As he said, you can run the numbers he said but keep the rears to 285 or smaller. For 295s not to rub on 10 inch rims, the offset MUST be between 39 and 42. Anything outside of that will rub on the inside or outside.
Old Feb 9, 2010 | 02:54 PM
swadhwani's Avatar
2009 E63 AMG
2009 E63's have different offsets, at least what the dealer told me...said it would be tough to STAR lower
Old Feb 9, 2010 | 03:10 PM
jangy's Avatar
2015 S212
All 211 E63s are the same in the rear but run an 18X8.5 vs the 18X8 that the E55s run. It doesn't change much, except you have to consider the different calipers front and rear when selecting wheels.
Old Feb 9, 2010 | 03:11 PM
jangy's Avatar
2015 S212
lower on stock setup? He lied. I've seen plenty of dumped E63s even on 20s and they look HOT!!!!
