LIMITED TIME! Evosport Performance Rotors...Save $400!
Old Feb 9, 2010 | 03:58 PM
Simon @ evosport's Avatar
PREMIER SPONSOR
Now through March 1st, we are offering our best-selling E/CLS/SL55 AMG Kompressor OE brake rotor replacements for $1,599 (that's $400 off the $1,999 price!). Shave over 34-LBS unsprung weight!
We haven't offered any deals like this on these since 2006!
Designed as a direct brake rotor replacement (front and rear) for the OE W211 E55, W219 CLS55 and R230 SL55 (rear only for 030 Package vehicles) AMG Kompressor brake rotors. No modifications are necessary. The rotors are designed to bolt directly to the OE AMG calipers. Not only will the upgraded multi-piece "floating" rotors help mitigate brake fade, but are lighter than stock and reduce unsprung weight by a total of 34-lbs. on all four corners! This means better acceleration, braking and cornering. In addition, you get to maintain the AMG calipers without going to a more expensive solution that requires replacing them.
Ask us about available brake pad options for this setup as well.
Benefits:
  • Lightweight multi-piece design using hard anodized aluminum hat offers huge weight savings over heavy OE one-piece rotors (over 35-lbs unsprung weight!)
  • Unlike OE rotors, which vent the wrong way on one side, our rotors are designed for proper Left/Right application for maximum venting/cooling
  • Easily installs with no modifications using OE brake calipers
  • Functional upgrade you can feel! Results in improved acceleration, braking and cornering
  • Floating design helps dissipate brake fade for street or track use
  • Replaceable discs so you don't need to purchase entire rotor
  • 2-year warranty on hardware
Discs are available in:
  • DRILLED/SLOTTED Design (best-seller): E55/CLS55 | SL55 [click for info]
Drilled/Slotted Design:
Slotted Design:
Old Feb 9, 2010 | 04:13 PM
Karlson's Avatar
06 E55
woho, thanks!
Old Feb 9, 2010 | 04:33 PM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
how much for front rotors only? and how much for delivery to Vegas?
Old Feb 9, 2010 | 04:42 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Did you said 34 lb???!!
Old Feb 9, 2010 | 04:47 PM
E55AMGGG04's Avatar
04 w211 E55
Oh man they look great and must perform excellent. I installed ceramic brake pads maybe 3 months ago would that cauz an problems ?
How many of these are left in stock ?
Old Feb 9, 2010 | 04:53 PM
citylightva's Avatar
2007 E63, 2005 Dodge Ram Hemi
It's the aluminum hats and being 2 piece..!! You should get their rears for your car. It's like -8lbs. per side...
Old Feb 9, 2010 | 04:56 PM
PREMIER SPONSOR
Front rotors are $1,100/pair. Rear rotors are $990/pair. $1,999 for all 4 or $1,599 at this special price.
Please email or PM us for ship quotes.
No, I said "over 34 lbs" I believe it's 34.4 lbs to be exact.
Should not be an issue. We've run everything from Pagids to track ready Porterfield pads. We have a few sets left, but they will go fast at this price!
Old Feb 9, 2010 | 04:57 PM
PREMIER SPONSOR
We have REARS for E63 now. Fronts for C/CLK/E/CLS/SL63 coming soon!
Old Feb 9, 2010 | 05:21 PM
The factory E63 AMG cross drilled pattern is opposite from Evosport's rotor, is Evosport's rotor designated as Right and left side or either way?
Old Feb 9, 2010 | 05:29 PM
PREMIER SPONSOR
To save cost, Mercedes OE rotor uses ONE part number front and ONE part number rear that can be interchanged Left or Right. This makes the factory rotors vent the wrong way on one side. Our rotors have a unique Left and Right application. This does make the pattern on ONE side different than the factory. We've sold over a hundred of these to CLK63 and C63 owners and it's hardly noticeable- I'd prefer the venting advantage over that anyway.
We will be releasing front rotors soon for 63 so that little issue will go away.
Old Feb 9, 2010 | 05:55 PM
Karlson's Avatar
06 E55
god damn. the shipping is outrageous thou. how come the shipping is $143 for the ground?
Old Feb 9, 2010 | 06:48 PM
PREMIER SPONSOR
No idea where you got that number but I just sent you a PM. It's much less than that, but 4 rotors is still a lot of weight.
Old Feb 9, 2010 | 06:53 PM
Karlson's Avatar
06 E55
I understand that they are pretty heavy, but I got that price while doing the checkout on your web-site
Old Feb 9, 2010 | 06:55 PM
PREMIER SPONSOR
Ah, got it. The website treats them as 2 separate boxes which is the case. I can fix that and we can ship as one box so shipping would be much less.
Old Feb 9, 2010 | 07:19 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Simon, I don't understand exactly what that issue is? Is it just the fact that one of the rotors will have an opposite pattern (just looks) or is there any type of electronic/mechanical issue when used for an E63?
Old Feb 9, 2010 | 07:32 PM
PREMIER SPONSOR
This is purely an aesthetic issue. As you said, one of the rotors on one side will have opposite pattern than the front (assuming you are using OE front). There are NO mechanical, electronic or any other functional issues. Hope this helps clarify it. Like I said, with the wheel bolten on it's really difficult to tell anyway.
Old Feb 17, 2010 | 09:40 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Simon,
What is the projected price for the complete set of two-piece rotors for the E63 (F&R)???
Toni
Old Feb 17, 2010 | 09:46 PM
PREMIER SPONSOR
Originally Posted by Yuille36
Simon,
Toni
We are targetting for the same price as the 55K, which is SRP $1,999 for all four corners. Taking pre-orders now. We estimate beginning delivery in 7-10 days.
Old Feb 25, 2010 | 01:17 PM
PREMIER SPONSOR
REMINDER: Last few days to take advantage of this offer. Interest has been overwhelming so don't miss out!
