Theoretical Discussion: Manual Tranny Swap?
Nothing worth listing.
This thread is just to gauge whether or not I'm the only one that feels this way...
Any other E55, or E63, owners out there sometimes wished they had a true manual transmission? I'm fully aware the current automatics may be better from even a performance standpoint due to it being able to shift through gears faster but what about the added control of a manual? There are already rebuild options out there that can make the auto's handle around 1200 horsepower... but how do you guys feel? This option might be a green light to higher levels of engine mods.
The pros are probably:
1. Added control to the driver. Some people simply like the third petal, or enjoy being able to choose exactly what gear they want to be in, etc.
2. Depending on transmission of choice, lighter weight?
3. Increased reliability, also depends on which transmission you choose. There are simply less things to go wrong on a conventional manual than the current automatic units.
Cons:
1. Cost
2. The recalibration of the ECU to accept a manual transmission might be tedious.
3. Worst performance (due to slower shifting) to those who aren't necessarily the best stick drivers
A few notable units that come to mind are the V160 units found in the twin-turbo Supras. This unit is capable of handling even 1600hp Supras and can be found pretty easily. Another is the T56 that comes in most V8 Chevy cars as well as a few special editions of mustangs, the viper, as well as an aston martin or two. Again, these units are rated to handle quite a lot of power too.
Please discuss.
Cons:
1. Cost
Please discuss.
you can't use the newer benz manuals b/c they also have an electronic ECU (hard to believe but true, dunno what in the world its needed for but it has one). The older ones suck and are cable driven. Your best bet is going with a non-benz tranny and customizing it to work. You will also need custom driveshaft and etc. A realistic budget for a job of this magnitude is probably $7-10k to do it right, so plan accordingly
2003 E55 & 2014 GL550
Anything is possible of course, but with the ECU and TCU in constant communication, I would put it more into the "private mission to moon or mars" category. It could be done but just so far out there in probability.
The code programming alone to change all that code communication would be
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Most of the time, you can just remove the TCU and the engine ECU will still operate totally fine. It will through a transmission service code light, but you can always just take out the bulb or etc. However, as cars get newer & newer, this is becoming much harder to do . Your best bet is just buying a manual car and not having to worry about this.
You can't turn a mule into a racehorse, some things just aren't worth the effort so I'd agree with your Moon analogy.
We aren't really turning a mule into a racehorse, its more like turning a really fast horse that has never had experience in a race, into a race horse.
2003 CL55 Kompressor Horizon Blue Metallic
Vince,
IMC, a trick for this type of thing is that the older Bosch units would work fine if the neutral pin on the wire harness as "lit up". Essentially, the ECU thinks the TCU is in neutral.
Unfortunately for our MB's, I seem to recall that the 55K won't rev much past 3000 RPM in neutral (??).
If there are manual tranny E's in Europe, you could probably source the pedal assemblies and asundry what nots from that route.
A lock and load internal shift rails manual transmission would be tons of fun in a 55K.
Vince,
quick search for "manual" in the 211 amg section:
https://mbworld.org/forums/search.php?searchid=5128107
i do remember someone once years ago talking about this, but backed out last minute. was it someone from HMS in cali (or maybe another shop in ca?)? i vaguely recall it was a silver w211 55. any older members remember?
2005, adaptation, amg, c43, conversion, e55, e63, ecu, manual, maual, mercedes, speed, swap, transmission, transmition, w211
