Headlight Restoration
Old Feb 15, 2010 | 10:02 PM
NSX2NV's Avatar
03' E55 Techtite Grey
I was wondering if anyone had any experience with refinishing their headlights. Mine are pretty hazey so I bought the 3M headlight refinishing kit. It came with several pads that sand and polish by using a drill. I haven't tried it yet but wanted to see if anyone has had any experience with trying to use this product or any others out there that you reccomend? Any input would be great!
Thanks!
Old Feb 15, 2010 | 11:26 PM
wizos6's Avatar
Audi s6
I guess if you fudge them up you can find a newer set on ebay...Wax on Wax off!!
Old Feb 15, 2010 | 11:47 PM
inrealtime's Avatar
2005 E55
I did it around a month ago. Mine where full of pits from rocks & some yellow hazing. It came out great. Made a big mess though. I did it in the garage. If I do my wife's car I will bring it outside.
There is a youtube video that 3M put out. It makes it very easy to do after watching the video. Alot of work, but the results made it worth it.
Old Feb 16, 2010 | 12:54 AM
NSX2NV's Avatar
Awesome I'll checkout the video Thanks!
Old Feb 16, 2010 | 09:33 AM
Luke_M's Avatar
E55, Supercharged Z4 (sold)
I've used that kit from 3m and it worked pretty good. Just follow the instructions and don't over do it. Make sure you tape everything off good too so you don't sand something you shouldn't have.
Old Feb 16, 2010 | 11:19 AM
TheVazha's Avatar
W213 E63
Yeah I did mine as well with the 3M kit. The lights did not come out like they do in the picture or in the video but for $18.99 its a HUGE improvement and well worth the low cost. Just make sure to use a good electric drill that has 1000+RPM.
Old Feb 16, 2010 | 11:21 AM
TheVazha's Avatar
W213 E63
Yes, go tape crazy!!! After about 30 minutes of sanding you get a little sloppy and I caught some paint on accident! Lucky it was with the clay 5000 grit disc!!
Old Feb 17, 2010 | 05:03 PM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
Before you go too crazy, figure out if they are fogged on the outside or the INSIDE! Many of these tended to fog on the inside so if you try to fix that with the 3M kit (or other), you are just wasting your time as it won't do a thing.
Old Feb 18, 2010 | 02:34 PM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
I used 2000 grit and some Zaino Z-PC Swirl Remover and it cleared them up fine. I imagine any brand of polishing compound or scratch remover would work too.
