Truth Revealed! Why good headers are a must!
PLATINUM SPONSOR
Just had a little fun cutting up a stock manifold and putting my handy mic to the flow areas.. First, it is amazing we can push 500 plus hp through holes this small. Those 50 year european emissions standards must be brutal! No wonder many members claim headers gave them their largest gains.
The stock manifolds, look kind of large to the eye but that is all there to hold heat in, keep heat off the motor and most of all to keep a tech from dropping a wrench and shattering the toothpicks we have for exhaust pipes..
Below is a stock manifold next to the tiny 1.42" ID pipe that runs inside it.. I taped a quarter over the stock manifold collector, just for reference.. Yes, all the exhaust flows through a center pipe that is 1.42 and then goes into a collector that is not much larger than a quarter.. 1.62" to be exact..
![](http://i991.photobucket.com/albums/af31/Vitabc/manifoldcompar.jpg)
Below: Stock collector ID. You can see the light tan sleeve inside the manifold.. The heat and back pressure on a moded motor must be immense.
![](http://i991.photobucket.com/albums/af31/Vitabc/collector.jpg)
Stock primary inlet into manifold.. Large weld blocks about 20% of the flow and this port measures 1.42, some are as tight as 1.38..
![](http://i991.photobucket.com/albums/af31/Vitabc/priamry.jpg)
What is really a crime, is that the exh. head port is larger than the manifold primary and the main tube all four primaries flow into.. 1.54" Below is a pic of the head port on my extra set of heads..
![](http://i991.photobucket.com/albums/af31/Vitabc/headport.jpg)
No secret, but I have been trying to find the right kind of headers for my body style and has been a major hold up on my build and even tuning.. Just hard to tune with so much boost and air going in and no way to get out! Jerry @ Eurocharged stepped up to help me out and is having a set of custom made high power/high flow set of headers ..
Jerry even offered to come over and help get them on, so we can make the Texas mile and HRP before our desert heat sets in..
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
2003 cl55 (sold)
Just curious..... on the short piece of pipe that connects the headers to the primary cat, how big is that? If I remember correctly, I believe it is only about 2 1/4", if that. I remember (I think it was Vadim, back in the not too distant past) offering a piece that connects to shorty headers (what I got) that was closer to 2.5" or something like that. Was thinking that would help open up the exhaust some more. Anybody ever try it or something similar? Does anybody offer something similar?
Brooke, your research always makes want to spend more money on my car! Haha but seriously I want LTs.
PLATINUM SPONSOR
Eurocharged is making a custom set of LT`s for me but still have to test fit them on the CL body style.. These will , well lets say be LARGE!
Not many parts for the CL, so as many of you know, I had to custom make or have made most everything on the car.. Well, the few mods I have..
I have spent 7 months of re-search and trying to get a set of LT`s but no luck on the flow parameters I want or gurantee of a fit.. I even gave a large deposit to a well known local Chasis (comp eliminator car builder) to custom make a set and he basically F-ed me out of it.. Still have to deal with that..
No problem bro, I think they are 1 5/8" anyway.
That short pipe is basically 2" od and with sloppy bends in it, even less flow than it measures.. Changing this would help if you have shorty headers and 2.75 would be the best size.. On a stock mnaifold, you may not be able to measure any gains from this, as the manifold is just to restrictive.. If I had the Evos, I would cut thier small collector off and just weld a 2.75" pipe onto the end and to the first cat.. This would help any shorty out tremendously..
![action](https://mbworld.org/forums/images/smilies/action1.gif)
prodigymb stock manifolds are in fact a joke. exotic sorry i didnt get a chance to measure my EVOs for you before I sold the car ....
Yesterday 11:42 PM
Yesterday 11:42 PM
jicl55 Just curious..... on the short piece of pipe that connects the headers to the primary cat, how big is that? If I remember correctly, I believe it is only about 2 1/4", if that. I remember (I think it was Vadim, back in the not too distant past) offering a piece that connects to shorty headers (what I got) that was closer to 2.5" or something like that. Was thinking that would help open up the exhaust some more. Anybody ever try it or something similar? Does anybody offer something similar?
__________________
www.ultimatepd.com
www.ultimatepd.com
E63 P30, CL500 Sport
Why does Mercedes/AMG go through all the efforts of creating an incredible engine, then slap those manifolds on.... they seem so under-developed for such a high performance vehicle
I understand emissions are strict, but I'm sure there are much better designs that would still be legal
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
2008 A8L, 2002 996TT X50, 2009 X5
I understand emissions are strict, but I'm sure there are much better designs that would still be legal ![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Should have titled this thread Truth Revealed! Why any headers are a must!
Obviously if you are going to upgrade it makes sense to go with good headers but looking at the cutaways of that stock mani it stands to reason that any header, even a poorly designed one, should show gains. Looking at how tiny the internals are its no surprise that even log style "headers" like the VRP Vadim style showed decent improvements. Even on my lowly E430 the stock manis (very similar to the E55K manis) are too restrictive for that engine. Its almost criminal that AMG went so small on the 55K.
PLATINUM SPONSOR
The Corvette c6-Zo6 and Zr1 have some of the best stock manifolds I have seen.. They even have their own runners and a huge oval collector..
__________________
www.ultimatepd.com
www.ultimatepd.com
V12-Biturbo
My old C6 Vette had horrible stock manifolds, I upgraded to Kooks 1 7/8 w/X-pipe/ Hi-flo kittens, difference was shocking to say the least, in Sound & HP/TQ
E63, S550
Those stock M5 headers look purdy
![Ladysman](https://mbworld.org/forums/images/smilies/ladysman.gif)
Those stock AMG headers look like something out of an economy car
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Even the stock headers from the Mustang 5.0 of yesteryear look better except for the pinches (see bottom header):
![](http://lib.store.yahoo.net/lib/mustangtuning/pypes-shorty-headers-87-93-02.jpg)
