Issues with akebono brake pads
Thought I would share a concern with all the good folks here.
On the back of the pads is an thin aluminum plate with black coating on it to help reduce noise and squeal. This plate is in direct contact with pistons of the caliper and rest on a small round pin that basically centers the pad on the disk, In my set 5 of the 8 pads had that plate mis aligned and it would not sit down on the centering pin correctly. I had to grind the plate down so it would fit correctly. Just something to look out for if your using this product. Here are a few pics, sorry for the quality, my camera sucks. The first pic is how its supposed to look the second you can see the plate sticking in the opening.
I'm UPGRADING my pulley! lol Somthing a little bigger than socially excepted. I'll give you a hint, there's a "5"in the size
LOLI think I saw a post a while back that claimed someone was running a 200.
How you liking the new pads ? It might be that they are new but they feel soft to me. Softer than than the factory pads. I'm used to performance pads having more bite.... we will see.
