Keyless issue on my 2006 E55
Old Apr 15, 2010 | 09:32 AM
ownersite's Avatar
2006 E55 Opal Black
I have some strange behavior with the keyless entry on my 2006.
I am no longer able to unlock the driver's door with the remote in my pocket.
The keyless go start works perfectly, as do all the other doors and the trunk. I've taken to opening the rear door first, which unlocks the other doors.
Could this be something as simple as a battery needing replacing, or should I take it to the dealer?
Old Apr 15, 2010 | 10:48 AM
Bellevue_E55's Avatar
2006 Mercedes E55
i replaced the battery and it fixed my opening. But I have a similar problem where I have to hit the button on the back door to lock the car.
Old Apr 15, 2010 | 10:49 AM
AMGSpartan's Avatar
2008 GL320 CDI, 2007 E320, 2005 Passat TDI
Hello ownersite,
Replacing the battery is a simply DIY that you could try. Since your Keyless Go still works fine along with the keyless door opening on the rear door, I suspect you have a 'bad' sensor or receiver for the front door. My car did this a while back and needed a receiver (I think?) to get it going. I let the dealer do that job so I don't have many details to share. Anyway...I bet it's more than just a battery in your remote that is failed.
/Sparticus
Old Apr 15, 2010 | 10:54 AM
ownersite's Avatar
2006 E55 Opal Black
Thanks for the replies. Not sure why I didn't check this before posting, but I tried the other key fob to see if it was the battery, and it still does not unlock the driver's door. Off to the dealer it seems...
The Law's Avatar
2006 E55 AMG
I posted on the same subject a few months ago. EXACT same issue. You need to take the car in to get fixed. The dealer will handle. I believe it is indeed the sensor.
Old Apr 15, 2010 | 11:38 AM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Another check
Hey ownersite, i had this issue when i first got my car and did lots of research on the subject. If "only" the driver's door does not unlock when you pull the handle yet all remaining doors and trunk work, then its the switch in the driver's door handle. These break quite often as i learned (which makes sense since its the most used handle on the car).
Also i'm convince you have the same problem as i did with these symptoms before because the driver and rear door handle on the driver's door both share the same sensor for the key so if the backdoor is working, that rules it out.
I grabbed mine at genuinemercedesparts.com (~$150) and the replacement took me less than 20 minutes. Hope this helps.
BTW i also drive an 06.
Old Apr 15, 2010 | 01:09 PM
ownersite's Avatar
2006 E55 Opal Black
Looks like three different people with 2006's have had the same problem. I sense a pattern here. (either that, or people without 2006's read the thread title and moved on)
I have to admit, that while I am a technical geek, I am not mechanically inclined. I hope the repair is covered under my CPO warranty.
Old May 7, 2010 | 11:10 AM
MrKool's Avatar
I am curious as to why isnt there a recall for this issue yet..!! I've got a 2004 and have the same issue.
nanayaw6, do you have the part number handy?
Old May 7, 2010 | 04:19 PM
jdeastbay's Avatar
2005 E55 / 2008 E63
Just went thru on my 08. Drivers door sensor had to be replace. Note they are usually not in stock and need to be ordered. Thought it would be something I could wait for and end up being 3 days...
Old May 7, 2010 | 11:25 PM
bigswin's Avatar
E63 AMG
Same thing happened to mine. Just had it fixed at the dealership, it was a bad door handle sensor.
Old May 8, 2010 | 01:13 AM
rlh23's Avatar
2004 SL55
Mine does the exact same thing
I changed the battery in my SmartKey yesterday, and that didn't solve the issue. It works on all of the other doors, but not the driver door. Quite annoying.
BTW, I've got a 2004.
Old May 8, 2010 | 02:22 AM
harjothundal's Avatar
05 e55
I have an 05 with the same issue. Mine started doing it intermittently around feb, and later it became permanent. All other doors/trunk/start operations work fine so I know the keyless system is functioning properly. I'm pretty sure it's a bad door sensor, havn't gotten around to replacing it yet.
Old May 8, 2010 | 06:10 AM
EdoubleNickel's Avatar
SOLD 04 E55 Now 93 w124 3.2 sold W210 E55 sold waiting on W211 E63 p030
mine did the same thing yesterday, I had to open and lock with read driver door. Now it works perfectly. Go figure.
Old May 8, 2010 | 09:38 AM
brettmf's Avatar
2006 E55
I had the same problem. I was told bad circuit in door handle. Covered with my Chrysler Warranty.
Old May 8, 2010 | 09:52 AM
Forrest Gump 9's Avatar
shrimp boat
By chance, do you still have the part number of the sensor?
My is an '04 and the driver door doesn't work, the other three doors work fine.
Old May 8, 2010 | 05:23 PM
MB2003E55's Avatar
2007 S600
Lightbulb
I had the dame behavior.
I had to replace the driver's side front door handle because the switch failed. It's a common problem with keyless go. The dealer told me I got the last Tectite Grey one in stock. MB discontinued the color in with the 05MY.
Old May 8, 2010 | 09:53 PM
azncantonw211's Avatar
2005 E55 & 2007 335iC
Change the battery :P I had the exact same problem and it solved it with the new battery
Old May 9, 2010 | 12:10 AM
MrKool's Avatar
Guys, can anybody post the part number for the front side door handle switch??
Mine locks from all doors and unlocks from all besides the driver side door and it looks like it might be the switch.
Old May 10, 2010 | 09:41 AM
ownersite's Avatar
2006 E55 Opal Black
The part number listed on my work order is 211-760-11-70-9189. Thankfully, the replacement was covered under the CPO warranty.
Old May 10, 2010 | 11:04 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
Looks like its ~$140 at parts.com. I'm thinking my 2006 has the same issue with the switch. I've been using the rear door to lock and unlock the car for a while now. Kind of annoying.
