Boost leaks with Thermalnator
Old Apr 24, 2010 | 03:55 PM
Roseylv's Avatar
w212 E63 / 996tt
To everyone who has spacers underneath the blower....
Which belt are you using (part # if you got it)
Have you had any problems with belts shredding?
Old Apr 24, 2010 | 03:56 PM
Roseylv's Avatar
w212 E63 / 996tt
Originally Posted by PTE
There is quite of bit a space between clamping area. ( Bolt Holes ). Which means that the clamp load between the bolts are less than the area around the bolts. If you look at the OEM Intake gasket. It is a 3 layer assy. The outer layer are a composite type material that is bonded to a Metal core. The assy also has stamped raised sealing ridge, Some areas of this ridge will flatten down a little , some areas will still have a very little ridge. This all helps seal & holds the seal against expansion & ( Hot engine ) & contraction (Cool engine) You may have two or Three options to resolve this type of issues. metal mating surface area must be very clean & oil free & dry. It you use the soft gasket (free) type Thermalater Heat spacer , I would suggest a attachment bolt Re torque after a motor has been brought to temp. Then cooled down. After the cool down ,re torque. I would do this a couple of times. You could increase the manifold clamping bolt torque , but I would switch to studs & Nuts.
I've always used a hard phenolic heat spacers , with a OEM gasket between it & The Head & Intake manifold. Cheers _PTEngineering
I may need to have my tech give this a shot before I do something drastic like pull the blower just to have these spacers removed. Thanks for the tip
Old Apr 24, 2010 | 04:17 PM
ahmad0658's Avatar
Brabus K8 E55 05
I have not noticed this problem until now, I am using the car on daily basis for about 2 weeks since I installed the spacers.
Old Apr 24, 2010 | 04:38 PM
Roseylv's Avatar
w212 E63 / 996tt
Eco,
I'm unclear!
Are you saying you have had problems with your supercharger belt or not?
Old Apr 24, 2010 | 05:18 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by sneakyneon
I'm a bit supprised no one asked about my oil catch can.....
that's ok, no one really asked about mine either...and it's been on there for two years now!
Old Apr 24, 2010 | 05:54 PM
ahmad0658's Avatar
Brabus K8 E55 05
Originally Posted by Roseylv
Eco,
I'm unclear!
No problem at all,
believe me, if i saw any problem , i may either take out the spacers or find a quick solution because the belt of Brabus cost 300 USD each. Yes, it is only the belt .
Old Apr 25, 2010 | 09:50 AM
  #32
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
cant detect it clearly but seems something similar to this separator for Hydrogen devices I bouth some time ago ..
if yes, let me know how it works ..
Uploaded with ImageShack.us
Old Apr 25, 2010 | 12:19 PM
  #33
sneakyneon's Avatar
Bicycle
LOL I'm not talking about the can, but yes its a water seperater for a air compressor but i'm refering to more of were is that 5/8 hose going to. I highly doubt anyone has this set up on there 55!!!
Old Apr 25, 2010 | 02:35 PM
  #34
chiromikey's Avatar
can't really see where it's going to but thanks for the hint. and you're right, i'm sure nobody else is running that set up.
Old Apr 25, 2010 | 02:56 PM
  #35
ahmad0658's Avatar
Brabus K8 E55 05
why do you use that thing ?
Old Apr 25, 2010 | 04:28 PM
  #36
sneakyneon's Avatar
Bicycle
An oil catch can is used to collect the oil that would normaly be ingested into the blower through the valve cover. Oil in your intake is not a good thing, it lowers octane and mucks everything up. My set up is diffrent in that I have plumbed my into the exh, the flow pulls out the oil residue under high load and is most usefull in a forced induction system becasue it helps stablize the piston in the bore improving ring seal. Its not a at all eco-friendly.
Old Apr 25, 2010 | 05:10 PM
  #37
ahmad0658's Avatar
Brabus K8 E55 05
Thanx for the explaination.
DIY will good way to show us how to set it up in our car ..
If anyone can do DIY, it would would so appreciated.
Old Apr 25, 2010 | 05:11 PM
  #38
dyno's Avatar
... suspected that
why not, then, connecting it to the egr valve
Old Apr 25, 2010 | 08:29 PM
  #39
sneakyneon's Avatar
Bicycle
I'd do some research before doing this mod, you may find thats its not what you want. A simpler oil catch can that is tied into the stock breather system might be more of what your looking for...
Old Apr 25, 2010 | 08:45 PM
  #40
sneakyneon's Avatar
Bicycle
... suspected that
I not sure how I'd go about doing that, or what pressure or flow would be nessasary? I though most times its just blocked? Not sure if tuning could fix the cel? Not sure how this effect the driveablity?
Old Apr 25, 2010 | 10:38 PM
  #41
KLR CLS's Avatar
CLS63 PP
Here is just a few, but you can see how the gasket is pushed out of shape on cyc 1 and that the gasket it self it basicly to big to fit correctly. Id be screwed if I had to pay someone to do this job!
Your valves are very clean. How many miles on the car? Is that the meth at work or what?
Old Apr 26, 2010 | 01:08 AM
  #42
MB_Forever's Avatar
E63 P30, CL500 Sport
Anyone else had problems with these thermalnators?
