Fog Light resistor install help...
Old 07-18-2010, 02:08 AM
FCSmthree's Avatar
95 C36
Originally Posted by jpohl402
The fogs look almost identical to the factory 5000-6000k Xenon low beams. The JDMTOY city lights, however, appear quite blu-ish and do not really match.
Here are bad quality ones....
May have found city light bulbs that match up better with the low beams and fogs potentially:
https://mbworld.org/forums/e-class-w...ed-review.html
Old 08-26-2010, 10:08 AM
peterliu2000's Avatar
e320
Originally Posted by ASP
sorry guys I miss spoke you will need to use a 50watt 3 ohm resistor. This will add about 50 watts of current drain to the wires making total drain for the foglight about 53 watts using the 96smd's. This should be close enough not to throw a error code. Install is simple just take one resistor wire hook it up to one of the wires to the foglight take the other side of the resistor hook it up to the other side creating a direct short between both the wires using the resistor "load equalizer". That resistor will get really hot so mount it on a metal surface to help it cool off. And yes it is supposed to get really really really hot so don't worry it's supposed to be that way. I've done hundreds of these, same step goes for the drl led or any other led's that throw faults just will have to use different resistors for different loads.
So the LED will use 53W(includes resistor) as the OEM bulb, it is a bad since not saving the watts and cost 3 +times more with a HOT resistor which may cause a fire or fuse break. try 10ohm to save battery (70% saving) if the computer ok with it.
Old 08-27-2010, 01:21 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Has anyone tried the error canceling LEDs instead? I have them for city lights with no resistors and with no errors.
Old 08-27-2010, 01:06 PM
e320
Website for the LED of City Lights?
Old 08-27-2010, 01:15 PM
pearlpower's Avatar
Search for '
T10 194 168 W5W Canbus Wedge LED Light Bulbs NO ERROR' on Ebay. Those are the city lights I purchased. No issues.
Old 08-27-2010, 01:28 PM
e320
It is a T4 LED light for interior which may not in the list of OBD check lamp software. The H1 LED for high-beam/driving/stop light has the problem with error message.
Old 12-01-2010, 04:06 PM
  #32
Eurohorses's Avatar
2005 E55
My Left HID foglight works for about 2 months, then starts to flicker, and finally dies after a day or two. Im on my 3rd ballast for the same side while the right side still has the original ballast. I do have resistors installed. Im tored of going through new ballasts.
What are my possible faults here? Maybe a faulty install on the resistor?
Old 12-03-2010, 04:02 AM
  #33
ASP
ASP's Avatar
2016 Freightliner "daily driver"
I got ballasts that are plug and play no warnings if you need them pm me .
Old 12-03-2010, 04:17 AM
  #34
ASP
ASP's Avatar
Glad to see there are still people that don't listen. Hundreds of cars, Zero Electrical fires, Zero Busted fuses, and Zero bulb warnings later one genius is here to tell us how its done. Oh thank god!!
Old 03-05-2015, 03:31 PM
  #35
iMakeLuv2myMB's Avatar
c300 sport
fogs
Im installling these risistors tonight anybody have instructions on how to do these?
Old 01-18-2021, 05:24 PM
  #36
Addi-c55's Avatar
C55 Amg
Originally Posted by mikey33
I ordered from IjdmToy and everything works great! You probably did not install the resistors correctly to the original wires. Here is a picture.
Put in 50w 3.3ohm resistors ( 10w led foglight )
worked well, for almost 10min and then one resistor popped.
maybe try 6ohm ? Any insight ?
Quick Reply: Fog Light resistor install help...
