Service D
Old Jun 10, 2010 | 10:10 PM
jaird23's Avatar
Service D
I just need more info on servce D...Is it just like
a service A/B? or theres more into it...thanks in advance..
Old Jun 10, 2010 | 11:45 PM
mikeevo's Avatar
2005 Silver E55
should be around 40,000 miles and its the bigger one with transfluid replacement and radiator flush and oil change, cabin filter and airfilter. blah blah blah 700-900 depending on your stealer I mean Dealer
Old Jun 11, 2010 | 02:20 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
A Service "D" should take about 4 hours to complete, it's Mikeevo stated. it's a typical service for oil, air filters along with a brake flush maybe a tranny flush, etc. But the car, will tell the technician what it requires, when they hook up the diagnostic computer to it.
Old Jun 14, 2010 | 07:29 AM
AreL11's Avatar
2006 E55 AMG
I'm due for a D in about 700mi. Gonna start calling to get prices today...
Old Jun 14, 2010 | 07:31 AM
JetJockey's Avatar
2006 E55
The Stealer around here just does an A or B. They do not perform the other "letters" for services. Not sure why, but that is what they do.
Old Jun 14, 2010 | 03:17 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
like Yuille36 said, the only thing definitive about a Service D is that the computer thinks it will take 4 hrs. As a result, a dealer can not quote it because they have no idea what materials may be involved in what your FSS thinks needs to be done.
You should use your maintenance manual to determine what needs to be done to your car. A good reason for doing that is when you bring the car in for a specific service, they may still reset the FSS completely. This happened to me when I had the transmission oil changed. I had to manually go in and delete the engine oil change and brake fluid change. FSS only gives you a limited time to do that. So the FSS may not be correct about what needs to be done on your car. Your records and maintenance manual are the way to go.
