shardul
Former Vendor of MBWorld
close
- Join DateMay 2008
- LocationHouston
iTrader Positive Feedback100
iTrader Feedback Score(1)
- Vehicle(s) I drive2003 W211 E55, 2003 W220 S600
Liked:295 Times in 244 Posts
So I was toying around with the idea of install a rear cooling reservoir. How do you all plumb it in as in the direction of the flow off coolant.
S/C heat exchanger > Additional pump > rear reservoir > front heat exchanger > IC pump > heat exchanger.
Is the above mentioned flow of coolant correct?
If you are adding the rear resevoir to add ice for the track I would do res > pump > intercooler > he > res. That way you are not heating the ice water through the HE before it goes to the sc.
shardul
close
- Join DateMay 2008
- LocationHouston
Quote:
thanks for the input. that makes sense. Originally Posted by blackbenzz
what would be the route if i wanted to increase coolant volume for on road use. Just short intervals of WOT. Or is it even worth it?
Currently Active Users (1)
