Will I need a tune if I get a heat exchanger and Johnson Pump?
If you do not mind me asking. What is the next step up after getting a heat exchanger and Johnson cm30 pump for cooling? I think I read something about two pumps but is that a lot more advantageous than using just one? thx.
No tune needed, and I have PLM and Johnson CM30. The PLM was not quite a bolt in on my cls( bolt spacing on bumper support is different than a E55), but should be a fairly straight forward affair on an E55. Quality is great and price can't be beat.
My .02
Pete
Doesn't mean that I won't be upgrading the cooling system but it hasn't troubled me thus far...
It was 90+ a week ago and the car ran strong as ever
I would definitely think that a bigger HE and johnson pump will more than fit your needs. Anyone else can tell me wrong but I think that the rear box is for the gnarcore of the guys on this board
I think the johnson pump I will do, but I am confused on if I should get the PLM because it is cheaper or the eurocharged. I know the PLM uses air to cool and the eurocharged liquid, but are they equal performance wise? Also, the eurocharged is an addition to the stock, but the PLM replaces the stock so there is only one correct?
