Meziere pump WP136S for the E55
Brabus K8 E55 05
I would like to get this IC pump instead of Johnson CM 30 pump,
http://www.meziere.com/ps-892-0-WP136S.aspx
But, I am wondering if it will be install and run directly like Johnson IC pump? Does it need any mod?
I would appreciate if someone can give more explanation.
yes.. same 2 cables to wire it.
just bigger and faster.
I have one in my garage, I have yet to install. I can't seem to find a good mounting bracket.. its twice as big as the CM30 pump.
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
it mounts vertically on the stock bracket. the bracket you want to use the one that has 3 mounting screws. there are 2 90 pieces of metal on the bracket that need to be grinded off. drill a hole in the bracket and use one of the supplied allen screws to mount the pump. took me 30 mins to do. I had my pump zipp tied first, then AUS-E55 came up with this idea to mount it.
Brabus K8 E55 05
As for mounting we will see what kind of fabrication can be done to solve the issue, I'm heading to the mechanic tomorrow to install it and fabricate the mounting. If everything went fine, I will take pics and hoping to have clear ones.
Brabus K8 E55 05
Thanx a lot mikey for the information and the pics that you uploaded, they were useful.
Here is mine installed, sorry because the pics are not clear.
We fabricated one mount and we used one clamp to support the pump from up just like mikey (only I used one clamp) and one tightened bolt from below as you can see on the pics.
@ Ecoscope you need to update sig with new pump info. LOL.. Also what is your new pump hook to I see H/E hooked up to other lines in picture 009.
Brabus K8 E55 05
Well, I can see what you mean, tricky picture really, I just noticed that now. Nothing extra ordenary here, HE is hooked to the pump and that is another line goes to the small HE below the front HE.
Brabus K8 E55 05
I forget to add that I used different hose instead of the one that goes out of the HE to the pump, the old one, was not good for the set up that I have, so the guy on the workshop got me another one from somewhere and it was cut to fit in the new set up.
2004 E55, 1997 E320 "Sold"
have u seen any changes from the car since fitting the mez pump
I was thinking of using this pump in my upcomming projects. If I do, I will make a mounting bracket to fit these AMGs.
1 Post
CLS 55 AMG, FX45, F-350, Top Secret Widebody Supra (Sold) and other vehicles on another Planet
Here is the bracket that Motorwerks here in Houston just fabricated this week for two of our CLS 55 AMGs. Twin CLS 55 builds currently in progress.
Shardul, I'm about to send you some photos!
Ty of Motorwerks working hard!
'04 E55 AMG
