E63 alignment....dealer says it takes special tool only they have. True or not?
Old Jul 2, 2010 | 01:11 PM
Meeyatch1's Avatar
'94 NSX,'99 NSX Z,'12 C63 Black Series (Prior: '07 E63, '08 CLK63 Black Series,'14 E63-S & 16 C63-S)
So I picked up my E63 today and when I asked about getting it aligned they said it was $160 - $170. Compare this to the $89 the Acura dealer charged to align my NSX (which I have watched them do, and it is not easy), and I was left to wonder why it was almost DOUBLE the cost. The Mercedes dealer claims that only they can align the car correctly because I have air suspension, and that they have some sort of rhombus tool that is required. Does this sound right? Am I stuck with going to them to get this done correctly?
Old Jul 2, 2010 | 01:23 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
I know the machine they use is very expensive and so not many independent shops bother to get it. However, if the shop is big enough, they may have one. Try calling around and ask for a shop that specializes in Mercedes or European vehicles and see if they can do it.
Old Jul 2, 2010 | 05:39 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Because of the airmatic you need a Romess inclinometer and SDS to set height.
As Mo says, find a good MB Indy or Euro shop that knows what they're doing. Or bite the bullet and do it at the dealer.
Do you really need an alignment? Is the car pulling or bad tire wear? Hit a huge pothole? These cars should stay in alignment unless something's happened.
Old Jul 2, 2010 | 08:13 PM
infantry's Avatar
07 E63. 07 STi limited #606/800
I have this problem with tire wear being very uneven and pulls right.
Old Jul 5, 2010 | 07:56 PM
Meeyatch1's Avatar
I am noticing a 'floating' feeling between 130 - 146 mph that makes me feel unsettled, and the steering wheel is off center.
Old Jul 7, 2010 | 12:08 PM
Meeyatch1's Avatar
So what the dealer is saying sounds legit then. Is this special tool something that an independent shop can obtain? Also, if the car is aligned without one, is it then not done correctly, and a waste of time and money?
Old Jul 7, 2010 | 12:24 PM
motorkas's Avatar
a Rivera...via a Custom 24, Strat and Les Paul
I was told by my indy shop to take it only to a MB dealership for alignment because of the reason you stated - my dealership only charged 99.00 so you may want shop around dealerships as well, but honestly, I know it's the principle and all but 70.00 for piece of mind at the speeds you're describing. . .; also, I've known a couple of people who have had NSX's and have let me driven them hard; at 70mph you can feel the increase in down force and they're just PLANTED from then on - I don't know if you're going to replicate that in the 63 but a suggestion may be to get an ELM to lower it to help with front end lift
Old Jul 7, 2010 | 10:48 PM
NCE500's Avatar
2007 E63, 2006 C55
RE: Alignment
While my independent does excellent out of pocket maintenance and repair work for less than the dealer, and has a flashy Bosch alignment machine, my experience has been that only the dealer is able to get alignment 100% on the W211 with airmatic. For reference, my dealer only charges $99.95 for alignment.
Old Jul 7, 2010 | 11:10 PM
phatmitzu's Avatar
2005 E55
Anyone thats lowered and had their car aligned at the dealership?
Old Jul 12, 2010 | 07:55 PM
viku_st's Avatar
07 E63
Is it $99 for the front only? I just was told the alignment on 4 wheels will start from 175 and go to 275 plus taxes. not bad
Old Jul 12, 2010 | 08:01 PM
MB_Forever's Avatar
My dealer charges $275 for alignment.... ($200 for my price)
Old Jul 12, 2010 | 08:42 PM
citylightva's Avatar
2007 E63, 2005 Dodge Ram Hemi
Hhmm I think I paid low 200's last time I had it aligned...
Old Jul 12, 2010 | 10:54 PM
Meeyatch1's Avatar
Thank you for the tip. You are right. I may be used to the fact that the NSX just feels glued to the road when running at higher speeds. What is the 'ELM' that you speak of to help the E63?
Old Jul 12, 2010 | 10:57 PM
Meeyatch1's Avatar
The consensus seems to be that to get it 100% right, which to me is the only real option, the dealer needs to do it. That is cool with me as long as I know the extra money is being paid for a legitimate reason. It is in there again getting some work done, and I will make sure the car is aligned while it is there. Especially at speed I want to make sure the car is stable, and that the suspension is 100% correct. Thanks everyone. I appreciate the help.
