Base of xenon bulb melted randomly... what the hell?
Old Jul 5, 2010 | 12:47 AM
Nait Sirhc's Avatar
2002 BMW M5, 1992 AWD DSM, 1988 Yamaha FZR1000
So I was driving home tonight, going around a cloverleaf on the interstate and wammo, a "low beam: right" warning message pops up.
I get home and check it out. This is what I find:
What the hell is this? Why would this happen? I'm assuming the entire ballast is dead, is this going to be covered under warranty?
Old Jul 5, 2010 | 01:07 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Are you sure those are OEM D2S
Old Jul 5, 2010 | 02:38 AM
Nait Sirhc's Avatar
They're D2S 5000k bulbs from ddmtuning.com
Old Jul 5, 2010 | 03:11 AM
blueacc333's Avatar
C300
how long did u have it?? probablly aftermarket...
Old Jul 5, 2010 | 03:17 AM
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
could be the bulb or it could have been a bad connection causing a charge to melt the base over time.
Old Jul 5, 2010 | 04:10 AM
Nait Sirhc's Avatar
I've had these bulbs for about a year.
Do you think the ballast will be warrantied? If not, how much is a new one?
Old Jul 5, 2010 | 04:35 AM
blueacc333's Avatar
C300
i see.. one year?? no warranty after one year.. unless they are really nice
Old Jul 5, 2010 | 01:05 PM
Nait Sirhc's Avatar
The car came with factory bixenons, I'm not too concerned about the bulbs being warrantied. I can get another set of bulbs for $50. I'm more worried about this little black and yellow box, if it'll be warrantied, and if not, how much it'll cost to replace.
Old Jul 5, 2010 | 01:10 PM
citylightva's Avatar
2007 E63, 2005 Dodge Ram Hemi
Looks like right around $100 for the ballast aftermarket...No idea what MB would charge...
Old Jul 5, 2010 | 01:54 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
The way I see it is that the stealer can refuse warranty due to the fact that you put in aftermarket bulbs. Therefore I hope you still have your OEM bulbs and they show a similar issue. Otherwise its GL.
Old Jul 5, 2010 | 02:16 PM
Nait Sirhc's Avatar
For the little black/yellow box? That's not too bad. Do I need a specific one since the car has bixenons? Where would I order it?
Old Jul 5, 2010 | 02:31 PM
Isn't that part just the bulb adapter..? Your ballast should be like a silver/metal box with a wire to this part...
Ignore that, have you tried swapping your ballast from side to side...? PITA i know, or did the end of the ballast wire melt too..?
http://www.kbcarstuff.com/OEM_HID_Xe...nents_s/32.htm generic Phillips ballast
and I thought they were Bosch ballasts, but I can't find any W211 on here...
http://www.auto-electronic.net/hidballast.htm
Last edited by citylightva; Jul 5, 2010 at 02:38 PM. Reason: Didn't read right....
Old Jul 5, 2010 | 02:35 PM
Nait Sirhc's Avatar
Oh, I'm sorry. I meant the igniter.
MB says the bulb itself is $187 (for ONE D2S BULB!!) and the igniter is $177. That seems like absolutely ridiculous prices, how is a single OEM D2S bulb $187?! Who do we use for OEM bulbs? Philips or Osram?
Old Jul 5, 2010 | 03:34 PM
EDITED, you can check those sites...but I don't see anything about MB 211 OEM...
Old Jul 5, 2010 | 04:46 PM
Nait Sirhc's Avatar
The ballast wires going to the igniter look fine. I am going into the dealer tomorrow, if they won't replace it under warranty I found another Hella igniter online for $70.
