Question for the Lowered guys...
Old Jul 7, 2010 | 10:04 PM
ShyGuy's Avatar
W211 E55
How many of you rub in the front when turning into a incline (ramp). I'm only lowered slightly and whenever I turn into a driveway at anything faster than a crawl, the top of the wheels will rub the fender. Over time I've noticed that my fenders are starting to warp because of this.
Old Jul 7, 2010 | 10:10 PM
smiley47's Avatar
2008 E63, 2010 SRX Turbo, 2010 Escalade EXT
What vehicle, what wheel size and what tire size do you have?
How much are you lowered?
Old Jul 7, 2010 | 10:16 PM
ShyGuy's Avatar
W211 E55
20x8.5" 245/35/20 in the front
My wheels aren't even that aggressive in terms of offset. They sit about 3/4" inside the fender. I'm lowered maybe 12-15mm in the front.
Old Jul 7, 2010 | 10:23 PM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
i am lowered about 2 inches on stock wheels -- no problems that i have noticed
Old Jul 8, 2010 | 12:21 AM
BenzoBoi's Avatar
Super Moderator
W221
Is your name Eric by any chance? Just wonderin???
If I were to guess, I'd bet your problem is the tire size. It should be a 245/30/20.
Old Jul 8, 2010 | 04:44 AM
ShyGuy's Avatar
W211 E55
Interesting...I didn't know that was the proper size for 20"
Old Jul 8, 2010 | 06:06 AM
acb's Avatar
acb
2005 e55 amg
Im lowered heaps and dont rub the wheels, although trying to avoid scraping the lip spoiler is a different story. Perhaps you can do what I do in those situations and just hit the raise button?
Old Jul 8, 2010 | 06:31 AM
jagass's Avatar
pick up
that's really the disadvantage of lowered cars, needs to have more care on driving. lol
Old Jul 8, 2010 | 01:29 PM
Neoii's Avatar
e500
Yup. You are riding on wheels that are 1" taller than OEM size. With variations in alignment specs, offsets, ... adding 1/2" to the gap increases the likelihood of rubbing.
Old Jul 8, 2010 | 01:44 PM
AMG4EmE's Avatar
2008 W211
Rubbing...
I had a slight rubbing issue with my 19's lowered on H&R's when turning into a driveway at anything above crawling speed. There was a barely noticeable dent starting to show at the top of the front fender. I had the front fenders rolled a bit for under $100.00 and the dent corrected itself during this process. I don't think rolling the fenders eliminates the rubbing tho. I think it only strengthens the bottom portion where the rubbing occurs allowing it to withstand the rub without the damage. I still take it slow going up driveways.
Old Jul 8, 2010 | 02:11 PM
novae500's Avatar
W211
i'm dropped 2.0 inches f/r on 19s x 8.5 and no issues when turning.
Old Jul 8, 2010 | 04:01 PM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
I can only add ones suggestion to all lowered cars when climbing up a ramp/driveway dont drive straight at it( 2 wheels a a time) but rather go at say a 45 degree angle turning in that way one wheel climbs at a time. I've found this has helped me quite a bit cos my front never scrapes, no rubbing and my diffuser fins clear just fine. Don't know my current measurements but current "raised" setting is the stock "normal" ride height at standstill. Also on 18" and stock tire sizes. Hope this helps
Old Jul 8, 2010 | 04:05 PM
W Cole's Avatar
makes your daughter horny
I'm running 19s with the correct size tires and my car will always scrape the fender if I pull into a driveway incorrectly. As said earlier come at it at a 45 degree angle and try to keep your wheels pointing as straight as possible. The rubbing occurs when you are turning sharp and the suspension compresses.
I think this has something to do with the W211 fender/suspension design because I see so many lowered W211s with fender damage.
Does anyone know somewhere in socal to repair this kind of damage to the fender? A talented paintless dent guy?
Old Jul 8, 2010 | 06:02 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Does your car raise up the the maximum original factory specs or is the raised height now 2" lower?
Old Jul 8, 2010 | 06:12 PM
yup - use the raise button -- i got tired of scraping the middle of my car on aggressive speed bumps -- now i am in the habit of using the button - no problems
Old Jul 8, 2010 | 06:49 PM
snail45's Avatar
E55 AMG
Yep. My passenger side tire rubs the fender sometimes with stock wheels and tire size. The driver side doesn't ever rub though. I have measured to see if they are the same height a few times and it always checks out good. Not sure why its just the passenger side.
