Loss of Power at 4000rpm
Old Jul 14, 2010 | 01:29 AM
hionbusa's Avatar
2005 E55 AMG DESIGNO
Hello All,
The beast has served me well the past 2 months but now Im running to couple issues . When I drive the car hard ,it runs good for the first couple minutes then all of the suddent the rpm cant get past 4000rpm . Look like it looses power right at 3500/4000rpm.
Also, I heard the s/c make small bird like whistle noise at moderate starts around 1500 to 2000rpm 1,2 gear with a very harsh kick engagement.
I did some research and aware of couple problems such as s/c clutch ,Intercooler malfunction. Some also mention these isssues to be common and normal!?!?
The car is under Chrysler warranty and thinking about taking to the dealer.
What do you guys recommend.
Any aftermarket fix for the intercooler ?
Thanks,
Old Jul 14, 2010 | 02:56 AM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
i have not had this problem -- but i know - everyone is going to tell you to check/replace your intercooler pump. I am sure that is going to be the 1st place to look -- and probably solve your problem
Old Jul 14, 2010 | 04:42 AM
tgoss's Avatar
'13 GT-R AMS Alpha 9+, CLA45, E55
Very wise advise. Bird noise = sc clutch
And the car simply will not go anywhere over 4k rpm? Not even at a snails pace?
Old Jul 14, 2010 | 07:54 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
If it won't go past 4k rpms. There is something else wrong other than the ic pump.
Old Jul 14, 2010 | 07:57 AM
930chas's Avatar
cornfed gtr and m3
I agree with Tal, you need to expand on the won't go past 4000rpm part. If the car literally won't go past 4000 rpm, then ic pump isn't your problem.
Old Jul 14, 2010 | 04:39 PM
hionbusa's Avatar
under normal driving . the engine revs with no issues. 1 st 2nd to 5th.
This only happen when going at higher speeds and pushing it hard with downshifts . Feels like the super charger just shuts down .The rev climbs but very very slowly...
Old Jul 14, 2010 | 04:48 PM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
check your oil gear also if it is not from the IC pump, i had this problem when my oil gear was low, it was doing the same thing as feeling loss of power.
Old Jul 14, 2010 | 04:55 PM
Infamouz's Avatar
C204, W209, W164
Well then just based on this... it sounds pretty straight forward, no?
Superchargers feed off of engine power and in turn produce more power. When at 4000 rpm, with a good working non-heat soaked S/C, it will climb quickly. When at 4000rpm, with the shut off S/C, the car will obviously climb slow due to the fact that it's missing at least 100+ hp, but still has to carry the same load.
As others have said, and if you haven't done so already, replace the pump. The pumps seem to be one of the best mods to keep that S/C going. For a fairly cheap cost, (of sub 200 from what I've read). If that doesn't solve the problem, it doesn't do anything else but help your car, and it's at least a starting point to figuring it out.
Old Jul 14, 2010 | 05:04 PM
shardul's Avatar
what is oil gear?
Old Jul 14, 2010 | 05:26 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
100% it's supercharger shutdown. I almost got killed by a Maxima when mine shutdown before all the cooling mods.
Talk about humiliation. Can you imagine that post on the Maxima forums.
Not sure if you have cooling mods but after you replace IC pump, time for a larger heat exchanger for you and to separate the systems. (last part is pretty easy)
Old Jul 14, 2010 | 07:22 PM
hionbusa's Avatar
Yep.. I was chasing an m3 and that's when I started to notice it ...
Any links for diy and where to buy ic pump ?
Old Jul 15, 2010 | 04:45 AM
Ali_E55's Avatar
Originally Posted by shardul
what is oil gear?
lol
i meant gear box oil level. (Autonatic Transsmission Fluid level).
sorry, coz when my gear oil level was low ( i know there is no sensor, but checked it manually) the S/C used to shut off after one hard hit. ( so the gear wont wear off).
after filling it, everything came back to normal.
Old Aug 23, 2022 | 12:43 PM
carlos88's Avatar
benz s63
S63
Wat pump you talking about cause I have the same problem with my s63 after 4000rpm it short down on power it slow and the tech people couldn’t even figure out
Old Aug 23, 2022 | 01:30 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
You are resurrecting a 12 year old thread lol
But he/she is referring to the intercooler water pump, to keep the IATs low. Bosch 010 is the sensible solution, but there are more powerful options possible
Old Aug 7, 2025 | 08:09 PM
Dancz19's Avatar
2005 Mercedes E55AMG
HEY there, I am having the same issues with my car.. Did you end up finding the solution to this?
Old Aug 8, 2025 | 06:16 PM
SICAMG's Avatar
2005 e55 AMG
Check the intercooler pump. Could be dead.
