My upgraded fuel system
Part 2
Its amazing how one thing leads to another. I'm sure after building an engine you know what I mean. there is no such thing as a drop in fuel pump upgrade and the big bosch's wont fit in the tank, so then that means you have mount them out side, but now the fuel line wont work that way so you have to run new line but the new line wont connect to the rail and now that you by passed the stock pumps the stock fliter and regulator are by passed so that means you need new ones of those. as you see it grows and grows and grows. This is hands down by far the most money spent on a mod to date.
85mm TB (82 bored)
Short headers that are less than desirable, no cats 3 inch into magnaflows
Some light port matching and blending on the tanks and IC
Water/meth
rear mount water tank
OE tunned (after one flash it was out of fuel)
My CAI has not proved any HP gain but no loss either so if anything its sounds cool!! lol
Crank case Evac
Fuel and more fuel
Intake/SC thermal spacers
I basical do all of the work my self, mostly out of poverty
I have two things that I really want to do, Long tube headers and a quife. Maybe fine tune the tune a bit.
Best pass has been 11.28 @ 128 I think theres more in her now the fuel is done.
128 is no joke..
what kind of shortys do you have..? thats my next mod for sure.
A pic is worth....
Part 2
One thing that has me a little concerned is the proximity of the open +ve lead of the right side pump to the mounting bracket... mbe the photo angle is exaggerating it a touch but mbe a boot to cover the power lead attachment on the pump?
I am curious why others running 550rwp+ have not had this fuel shortage issue... ? Is this mbe not an ECU / tuning thing or fuel line pressure / injector issue?
You got some super mods ...
so it makes the S/C sucks some hot air, and removing them may make the IAT a bit cooler ??
there is no harm in removing them right ?
I have a question on the stock system. Does the stock system have the single feed line to the engine and NO return line?
I understand the stock fuel pressure regulator is located in the tank with the pump. If this is the case, MB decided to comply with the 2005 US EPA mandate to eliminate the fuel return line from the engine. IMHO this is a major flaw in a performance vehicle and a big stress on the fuel delivery components which now have to be limited in the fuel tank. The fuel pressure regulator needs to be at the engine just after the fuel rail and the fuel pump must be allowed to flow constant pressure and volume to provide the needed flow and volume to the engine at pleak loads.
Again, nice work.
We just got ours back from the dealer from a repeated failure of the level sensor leaking and I have started to look into why the E55 is having this problem.
Again, nice work.
