Driving around in the city today, my ect was 199 farenhieght, once I turned on the fan to 99 setting, the temps dropped to 186! Not to shabby...
Although, it sounds like the car is about to lift off haha...
Did mine also on a 07 E63... The 99 number was way to loud, so I kept it at 66. Does anyone know the function order in the A/C menu for the E63?.. It does not match the prior posts function order for the E55s.
bumping an old thread here... i have not found a definative way to access this on an MY2005, production date 07/04... holding REST or the drivers AUTO button does not work, ive tried setting it to 72 and 75 degrees on both sides, to no avail... my control panel...
I tried this on my 2004 E55, and while I could access the menu, it didn't make any changes to the fan speed no matter what settings I changed (I tried every one listed on many threads)
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
Originally Posted by mercuxio
And Option 20 seems to be the thermotronic LCD display brightness instead of whatever the have put in the forums. What I don't understand is that the settings can go from 0-99 then beyond that is a number with a small block like this -> "█00", "█01". It seems to be like a number 1 the █ is representing. But why wouldn't they just put a 1 instead of a █ ? When it hits "█01" the setting is super bright but the night auto dimming doesn't work.
Did I just read this right are you saying you can turn up the brightness of the greeny/blue AC display unit other than turning the knob to turn the cluster and AC panel brightness up at the same time?
If so you just made my day because mine has always been dim no matter if you had the brightness knob for the cluster up all the way or not!!
That one should almost be a sticky because im sure im not the only one with that highly annoying issue and im sure people have gone to the length of replacing the bloody thing!!!
