Old Jun 24, 2015, 07:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels and Tires
Print Wikipost
Tire keeps leaking air
Old Aug 7, 2010 | 03:53 PM
dacls63amg's Avatar
2008 CLS63 AMG
So I have the lorinser 20in light wight rims. Noticed that the air pressure would drop 10psi every week or so. Went to the dealer and they said that the rims had a little divet or something. I said ok fix it. There solution was just adding more weld onto the rim. Got the car back about a week ago and still losing air pressure. Any thoughts? Could it be the rim or a busted tire?
Old Aug 7, 2010 | 03:55 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
could be a bad bead on the tire....
Old Aug 7, 2010 | 05:47 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
If the rims is fractured, it would account for the air loss. I would visit a tire shop, and have them add air to the tire, then submerge it in water to determine exactly where the leak is coming from. Just my .02 cents
Old Aug 7, 2010 | 06:50 PM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
yeah - submerge it -- it could be a valve stem -- mine was doing the same thing -- it ended up being a simple fix -- the valve stem cap had a rubber O-ring, it got stuck on the inflating pin and was causing a small leak --- tossed that ring and its been fine -- So, your ordeal could be a simple fix
Old Aug 7, 2010 | 07:21 PM
Nasty50-Five's Avatar
05 E55 AMG
Valve stem was leaking on my old car too, took months to find, the actual valve stem was rubbing against the rims and caused a little cut in the valve stem.
Old Aug 7, 2010 | 10:46 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
This is the route I would take.
Old Aug 7, 2010 | 10:55 PM
beauphus's Avatar
CLS55 & CL CK60
Could also be a bad seal between rim halves
Old Aug 8, 2010 | 01:21 AM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
mine was loosing a few psi a week, it was a leaky valve
Old Aug 8, 2010 | 12:01 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
+1
