Forged Pistons Were to get them
Rating: Thread Rating: 6 votes, 5.00 average.
Old 08-11-2010, 10:47 AM
bnzuovr's Avatar
2004 W211 E55K, GL550
Im looking to get a set of Forged pistons for the E55. I Did a search on here and on google did'nt seem to come up with anything. So if anybody knows were and how much i can get forged pistons for i would greatly appreciate it. Thanks in advance. Also i thought i read on here somewhere that the SLR Pistons were forged and would work on our E55 Correct me if im wrong.
Old 08-11-2010, 10:54 AM
Former Vendor of MBWorld
MBH motorsports's Avatar
C63, SL55, E55, CLS55, ML63, C55
I'd do SLR pistons.
Old 08-11-2010, 10:55 AM
Forrest Gump 9's Avatar
shrimp boat
pm MrBig, he has a set for sale in the performance section.
Old 08-11-2010, 11:13 AM
bnzuovr's Avatar
Originally Posted by MBH motorsports
I'd do SLR pistons.
can you pm me a quote please.
I will check it out thanks guys for the quick reply!!!
Old 08-11-2010, 11:40 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
I just can't even IMAGINE how much they would charge for 8 SLR pistons.
If you guys ever get a quote, lemme know.
I would guess around 1500 per.
Aren't stockers around 800 per from Benz?
Old 08-11-2010, 12:04 PM
citylightva's Avatar
2007 E63, 2005 Dodge Ram Hemi
You could always get them custom made...
Old 08-11-2010, 12:56 PM
FRC Z51's Avatar
Viper GTS
Call JE Pistons. They usually do custom pistons for ~$150 each.
Old 08-11-2010, 01:13 PM
kjlindgr's Avatar
Viking War Ship
CP just did some for mine so I'm sure they have the designs to make more. You need to order through a CP dealer though if I'm not mistaken.
Old 08-11-2010, 02:14 PM
bnzuovr's Avatar
i just checked my all data at work and the stock pistons are about 660.00each SO if i got them custom made would i have to send out the pistons in my car to JE pistons or how ever or how does that work. Thanks again guys don't know were the hell i would be with out this forum and all the help.
Old 08-11-2010, 05:50 PM
blackbenzz's Avatar
haters crazy
Just remember mb cylinder walls are coated. If you find a drop in piston that will work for a reasonable price count me in for a set too
Old 08-11-2010, 05:54 PM
kjlindgr's Avatar
Viking War Ship
The stock sleeves are Alusil. I had my piston skirts coated at Swain to work with the bore material. I'm sure they can give recommendations on whether this is needed or not.
If I had to do it over, I would have resleeved the block and tried to shoot for 6.0L
Old 08-11-2010, 07:34 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Talk to RennTech, I believe they were able to get the SLR pistons (at least) a couple of times in the past for a few fellow enthusiasts
Old 08-11-2010, 07:45 PM
BlownV8's Avatar
Received 1,071 Likes on 859 Posts
E55, GLS450, GL63, GLE350
Most are Alusil. J&E does not make a piston that will work in an Alusil bore. The only piston manufacturers that have extensive knowledge and actually make pistons that work and last in the Alusil bore are Kolbenschmidt and Mahle. Don't waste your engine trying to make another piston work. The only other proven options are to cote the bores with Nikasil or resleave with iron cylinder liners.
Old 08-11-2010, 07:48 PM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
I run wiseco`s and Nickasil coated bore.. Had to shim rod to piston clearance though. Wiseco and few others can not forge the pistons to the narrow piston to rod tolerances we need. My set up works well and takes a lot of abuse.. I now have 16K on my build.
CP would be a good choice, if they can meet the tolerances..
I prefer Nickasil over Alumisil..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 08-11-2010, 10:04 PM
Does anyone like Carillo make rods for them..??
Old 08-11-2010, 10:07 PM
PLATINUM SPONSOR
2003 CL55
Most rod companies will custom build them for you, just send a stocker.. Our stock rods are made damn tough and we have 6 bolt cross drilled mains..
__________________
www.ultimatepd.com
Old 08-11-2010, 10:33 PM
blackbenzz's Avatar
haters crazy
I got a quote from them years ago for a custom set and it was pretty expensive. Over $3k if I remember correctly
Old 08-12-2010, 07:37 AM
MRAMG1's Avatar
S600, GL450, Audi A5 Cab
What about Crower
They made me some damm good rods, NON MB, a few years back for around $1200.
Old 08-12-2010, 08:45 AM
TTMotorsports's Avatar
Whatever we're tuning!
I've used Oliver a number of times and their products are awesome!
http://www.oliverconnectingrods.com/story.html
Old 08-12-2010, 09:42 AM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
Maybe I missed something here, but why do you need pistons?
Nick
Old 08-12-2010, 10:58 AM
CLK DTM pistons $650 each.
Old 08-12-2010, 11:32 AM
blackbenzz's Avatar
haters crazy
$5k for pistons is not a reasonable price if you ask me.
Old 08-12-2010, 11:33 AM
I agree.
I dont even know if that includes anything too. Or if its just for the piston itself.
Old 08-12-2010, 04:22 PM
bnzuovr's Avatar
Nick
Yes that is the reason why i need to replace or over haul my engine. Cyl 8 Piston has a quarter sized hole melted through the piston trying understand why this happened. But needless to say im thinking maybe i can get the forged pistons & maybe a ported and polished head installed if the dealer is willing to do the install. My friend is my S.A SO this may work.
Old 08-13-2010, 01:12 AM
BlownV8's Avatar
Unless your cylinder wall is damaged, just rehone the cylcinder and replace with a stock piston and call it a day. A set of Mahle or Kolbenschmidt forged pistons will run around $4,000 but they will work.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
Quick Reply: Forged Pistons Were to get them
