Stage 1 vs Stock
Stage 1 vs Stock
What I'm looking for is how much speed did you pick up and how much et did you knock off after going from stock to stage 1? (please list your pulley size)
Stage 1 = Pulley & ECU Tune.......
Former Vendor of MBWorld
2015 S212
I went with the first version of the VRP 178 (180) and started with the powerchip flash. At the time, we gained major low end and lost top end. After some time tuning, the stage 1 became the best bang for the buck.
Times and speeds are relative but I went from just over 13 seconds to just over 12.5, so half a second. My 60 did not improve but my trap went from consistent 116mph to 122mph. The car did very well up until the 1/8th mie where it would fall on its face. Later, cooling, and openning the intake and exhaust took care of some of it....
a Rivera...via a Custom 24, Strat and Les Paul
Don't have a pulley - just a "J" tune - here's the Dyno with that. It has been only run at the track once so no baseline but Clayton pulled the last run of the day on street tires and in 90 degree weather and ran a 12.2. Everybody says with the right DA's and temps it's easily in the high 11's. To put it into perspective - my fastest time of the night was 12.8 so over half a second was just the result of the driver (Clayton is absolutely NASTY with his launches and driving skills - If I ever bet against him - I'm playing golf the next day with him so I can get my money back I believe he cut a 1.7 60 (it was his first time in the car and once again, it was on street tires).
Oh yeah - my trap speeds were 114 with the 12.8 and Clayton's was 112 - almost 113 with the 12.2.
I'm personally staying with the stock pulley but adding Kleeman headers and race cats.
Hope the info helps
Hope the info helps
2004 E55 AMG
This is all on street tires and traction limited.
My best time stock was a 12.11 @ 116 MPH.
My average time stock hot-lapping was ~ 12.25 - 12.30 @ 114-115 MPH
My best time with 180mm and tune was 11.98 @ 116 MPH.
My average time with 180mm and tune hot lapping was 12.05 - 12.10 @ 116 MPH.
Outside temperature was ~70 to 85 degrees depending on the day.
All of the gains are in the first 1/8th mile, and then the car actually runs the same or slower the last 1/8th. On the street it is an awesome combination, but without cold weather it doesn't really perform at the track.
Very helpful thread. Getting the 180mm, upgraded HE and tune next week. Once on I will get it dyno'd at Dynocomp and post it here.
It will be in AZ during the summer (so 115) so I expect the dyno numbers to be lower but I'll still post them here.
Like most of you I don't got to 100 MPH often, so my upgrades are more for fun on the street during my commute. (0-75MPH lanches, that sort of thing.)
Alex
Alex
E63 P30, CL500 Sport
I remember MikesAMG picked up a lot of ET and trap after stage 1 and drag radials. At the time, I think he was the quickest/fastest Stage 1 in the west coast.
best time 100% stock was 12.4 at 113
180,H/E,tune 12.65 at 116
stock pulley and tune/HE 12.2@117.30
Iv added kleemann headers with cat delete and will hit the track soon.I should break 119mph on stock boost and then Im adding a 168 or 172 and fianlly be done with the car
Stock - 12.1 at 118mph (street tires)
172 pulley and LET Shelf Tune - 11.55 at 120.9mph (drag radials)
Unfortunately my runs were done on different tires so not a true comparison. But the difference in mph is evidence of the power gain
First time at the track with this car, best was 12.0@115.85. This was LET tune only.
Seems like the posted results dont get much faster with more boost. I would have thought you would pick up at least 3-4 mph with any pulley.
2004 E55 AMG
I thought so too, but during the Summer it's not going to happen. I've ben fortunate enough to have a couple of 55-60 degree mornings since I got the pulley, and it's like the car picked up 50hp. I can guarantee that when the temperature is in the 40's and 50's we'll see that 3-4 mph easy. I'm planning on going to the track in October to test this, but there is a huge SOTP difference as temperature changes.
That is GREAT MAN!! I cannot believe that, we should all be so lucky to have a son so bright. Id say if he graduates you give him the car? HAHAHAHAHA
yeah he's a good kid, i just hope he stays that way. college life has a weird way of changing people. if you're ever in fresno let me and i'll have him meet up with you.
Both runs were done with the temp around the high 40's. I didnt do anythig as far as prep...as a matter of fact both of those runs were done after hot lapping.
1 Post
2008 ML63 2009 SL63 2010 Alpha 7 GTR
umm i think around 11.7, low trap speeds of around 116, I'm pretty sure I need a retune, I think I'm pulling timing up top. this was with 1.7 60'ft. I ran 12.6 stock with a 2.2 60ft' Im unsure what the traps were when she was stock. I should be running 11.5's with a good tune.
1 Post
I have run higher traps with slow 1/4 times, and slower 60ft. I consistency run 11.9s with no problem at all, cold. hot, first run, last run...so on...
Hope the info helps
Hope the info helps
You're too kind.
Seeing how you kicked my butt in golf today, what do I owe you?
