FUEL ISSUES!!!! WTF is up with this car??
. Ok so I replaced the fuel pump, put new seals and replaced the line that was leaking.. Good to go... all is fixed NO LEAKS..... Now tonight(not even 2hours after I did the job). I started smelling gas. So I pull over and Go mobile-mechanic right then and there.. I found no leaks. However the fuel tank and the metal frame under the seat is ****ing HOT! I mean really HOT.. Unsafe Hot. I'm not really one to rant at all, but im beginning to think that this car is unsafe. I drive around with my 2 kids, I give my mom the car at times and I am always on the road 30k miles/year... I'm just looking for anyone to shed some light on this issue, Any similar experiences?.... I feel like giving up on the car and selling it dirt cheap....
thanks
file a complaint like everyone else bc i had to go thru all that crap as well
https://mbworld.org/forums/w211-amg/...all-bombs.html
The best bet is to check this out yourself before something happens. Go to the thread above and follow the step by step procedure to check the fuel level sensor seals. It takes 5 minutes and a 8mm socket.
Fill the car up close to home, drive home, take rear seat out, open two inspection covers and look for gas in/around the two level sensor assem.
So if you wish to check that area then just fill up the car and drive it a couple miles. Stop and pop both covers off. If the level sensors are leaking at all....you will see the gas and smell it.
On a side note. One other member on this forum has eliminated all the stock fuel system and ran his own fuel supply/regulator/return line setup. He is running a fuel feed line up to the engine....a fuel pressure regulator at the engine....and then a fuel return line. This is how the car should have come from the factory. If we keep this car....that may be the only long term solution. I still say the EPA mandate and redesign of the fuel return line is why we are having this problem to begin with. Our cars do not have a fuel return line and the fuel pressure regulator is in the tank. That is why there is a hornets nest of hoses in the tank. EPA decided that emissions was better if the cars had no fuel return line. In my opinion a stupid move.
