Methanol Injection Install DIY - FINALLY!
Im going over to the dark side!
http://cgi.ebay.com/ebaymotors/Subar...item4aa44c8905
Your Joking Right ????
any so cal shops that could do the full install?
Summer is almost gone.. but methanol injection could be kept just for the "what if's"
The install will run you a few bucks unless you are super handy like these maniacs
ACG San Diego (Sponser) can do your install. Tell them Dane sent you (They might make you leave)
www.execstudio.com
Again, great write up
If I am correct, and tune to comensate for the richness, then if/when I run out of mix, it will be lean. I am pretty sure I can keep this in check, but I am sure you have already thought this through. Thanks Shardul!
Give it a try and report back....
