EC 550 Injector Install and Review
The injectors come neatly individually packed and coded with all the flow specs per injector on a data card.While not Identical to OEM injectors, they fit in replacement just fine. Two points to note, I swapped the top o-ring with the one on the stock injector because it was a little fatter and snugged into the rail better, and the the retaining clips don't quite fit right because the new injectors do not have the side reliefs cut in for the clips to fit. This really isn't a problem because once the rail is bolted down they are not going anywhere.
Install was straight forward. Surge tanks need to come off to access the fuel rails. Besure and let the car sit for some time for the rail pressure to subside or run the car and pull the fuel pump fuse and let it die. Else when you undo the fuel line you are going to get a gusher of fuel. Be sure and have a rag handy to soak up as it comes out. The inject wire clips are a little tricky but take your time and do not force them. Once all wires are undone, the rail and injectors will come right out. Drain the remaining fuel from the line and flip it upside down to pull the retaining clips and swap the injectors. The injectors feel pretty tight in there, but pull up and they will eventually come out. Reinstall along with you new ECU tune and off you go.
REVIEW:
I installed the new injectors along with new spark plugs and new EC tune on my ecu. While I was at it I shaft ported the Stock TB and ported my surge tanks and painted them black. Took my time over 2 days and I am very happy with the results. As a side note when I meet the ******* that decided 16 plugs was required I am going to punch him in the nuts. What a pain in the *** to change those!
Car fired right up and immediately It felt different. I could really hear the new airflow difference from the porting, and reved much more freely. I let it warm up for a few minutes, then back her out the driveway. Got underway and just barely leaned into the throttle an tires broke loose. Really not even trying to do anything. Found an appropriate road and got on it. First gear, useless. Second gear, useless. 3rd tires spinnging at 50. Got on the highway and gave it a few kickdown pulls. A normal 2-3 second blast that normally got the car from 100kph to 150kph pre porting, injectors and tune was now pulling to 170khp. Litterally a 3 second kickdown almost doubles your speed. I'll dyno soon, but based on comparison to other mods done so far I would guess a 40 whp pickup at least. And best of all I don't have this nagging feeling like I am going to run out of fuel and grenade my uber expensive motor. That alone would have been worth the money, but honestly the power pickup has made this car obscenely fast.
Thanks again to Jerry and Jake at EC for raising the bar again, and offering another great product.
Pete
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
I actually had a long talk with Jerry and he actually recommended that I stay with what I have after describing my logs and driving style to him. Not to say that I won't go with bigger injectors but I don't personally see any gains out of them except for the added comfort of knowing I'll have plenty of fuel on a high speed run. I run dual widebands in my car and my AFR's are between 11.6 - 11.9 through my entire 3rd gear with zero spikes. My thing is the 1/4 mile and to be honest I don't have roads or air strips that will allow me to exceed speeds over 170.
Thanks for the full review and your input and thoughts are appreciated.
https://mbworld.org/forums/4243220-post11.html
To tell the truth, I considered doing the mod but I just couldn't get myself to hack up my Renntech TB. All though I will do it if someone could definitely show me some proven gains either on the track or dyno. I believe this mod came from Brooke and props to him for thinking outside of the box.
Once everything is strapped on and I have Jeremy tune it I will head out to the track. I only have 1/4 times from my portable at the moment.
Two things are certain, your MPH(116) is very low considering your mods before the changes. Second, you are now happy with the way it is running.
Thanks for sharing, enjoy it, and get her back to the track!
In regards to the shaft shaving/porting, I find it hard to believe it gains much power since as Alan stated he gained 18whp by going to a 4mm larger diameter TB. You think shaving the shaft really adds more power than that? I will look for another TB to play with. If I find one before friday (and it doesnt rain then) I will put this debate to rest. Run with my current unmodified 82mm and then run with a ported shaft TB (swap TB's at the track). Can't get a better comparison than that. My 60's are pretty consistent but we can just look at trap speeds to keep it fair. If anyone has a lead on a cheap 82mm TB let me know. Or even if you are willing to let me borrow one and port the shaft for you (for free).
Either way we would know for sure...lol.
Props to the op for sharing and I am glad he is happy with the results.
Count me as one of the skeptics re the tb, I would more likely point to new plugs/injectors as the primary reasons for the gains.
THrottle body swaps aren't that fast, you do have to pull the supercharger...
An 80mm TB is not 80mm, closer to 78mm. This has been discussed in the past.
Here is some decent discussion here on it w/ some math. As you stated the 80tb will give 20hp, there you have it right there. We are claiming perhaps 15-20 which is what you also stated compared to a 80mm TB.
https://mbworld.org/forums/w211-amg/327281-74mm-tb-shaft-grinded-5mm-complement-exotic_metal55.html
NOBODY here is claiming the TB shave will net 40hp, again, your choosing what you want for arguments sake. Show me where anyone has claimed 40hp from a TB grind?
There are several variables that could have come into play as he did a few things to his car beyond just a shave. Keeping in mind the #8 cylinder which seems to be starved for fuel vs other cylinders could also possibly benefit from the additional fuel the larger injector in the kit allows, even over the remaining 7 larger injectors. I'm guessing the #8 injector is now 600cc vs 550cs for the other 7 cylinders. He also had a tune and MOST of us agree that HP/TQ can be gained from a proper tune. So why would a total of 40hp be out of the question? I'm not going to doubt the OP because I have no idea what his car was like before hand. Bad plugs, poor tune, bad #8 cylinder,etc.
If someone wants to mod their car, so be it. EVERY single person here that has done the TB mod has reported back with positive results. EVERY one of them. Every little bit helps, even if the TB shave was worth 10hp, 10 here, 10 there, it all adds up. It is worth it to some, perhaps not to others, but there is no need to knock what you have not even attempted.
There are those that believe tires/wheels will never improve handling, a dyno is not representative of mods, that more airflow does not matter, that exhaust is a waste, pulleys are not proven,etc,etc,etc,etc. There will always be those in one those camps.
Ultimately, internet tuning is one thing, at the track is where it counts.
You guys have all this crap wrong ..
Didn`t anyone read all my fuel injector threads, TB porting threads, fuel PSI and the info I posted? I did all the testing and foot work on our fuel and injectors.. Funny, I post the info and questions a few weeks ago and noone knew anything.. Now all the sudden , after I post weeks worth of info and we got frickin experts coming out the walls..lolPS, Really? running a 50 to 100 cc larger injector in one cylinder.. Really? Come on now..
www.ultimatepd.com
550 CC Imjectors
New NGK Iridium plugs with a 7 heat range
Shaft ported and ported/knife edged and blended circumference TB
Ported Surge tanks
And New EC Tune
It "feels" like 40whp pickup on the butt dyno. Any one of those factors can be adding to the current state of tune. I once changed plugs and gap on my modded TT 300ZX back in the day and picked up 18whp. Considering I have modded the car to be up 96whp and 125 wtq I know what various levels of power increase have felt like. All I know is how the car ran before and after since those mods. More specifically with the new parts and current tune, the car is a monster and it was no slouch before. The only reason it trapped 116 was because It was a 36 Degrees C at track level, and my IAT's were upper 190's by the end of the run. I ran like a monster out to half track then fell on it's face top end. I also ran with 3/4 tank and a trunk of tools, on 20" street tires so hardly well prepped for the track. If I can keep the car making the power it is now throughout the run, I have no doubt there is a low 11 in her on street tires.
Anyhow, I will dyno shortly and just received my LC1 wideband to go along with my OT2 to get some good logging as I go. Morale of the story here is I installed the new injectors, they run great and the car is making more power, safer then before so I am very happy about that.
Pete
