Hello MbWorld members, NEED HELP ON AIRMATIC STAR DROP
Subscribe
Sep 12, 2010 | 06:30 PM
I have played around with the settings for a bit with the DYI thread on the star diagnostic how to, but i havent had any luck. Is there someone that could help cause i tried the seetings on the DYI to be exact and ran the car at 80 mph came back to the shop and no change...thanks in advanced def need to drop the murdered out E55 Beast...
Reply 0
Sep 14, 2010 | 12:13 PM
help please
Reply 0
Sep 14, 2010 | 12:15 PM
more information please.....
Did you do the drop and turned car off and it went back up? I am not following....
Kinda sounds like you didn't save the settings or do it from the right screen.
Try raising the car while stopped, and then bringing it back down and see where it sits.
Reply 0
Sep 14, 2010 | 01:15 PM
Ok listen up Bob Hodges, go to this thread:
https://mbworld.org/forums/w211-amg/...ts-o-pics.html
Follow the instructions and you will have the cleanest drop ever. I did mine with star and the car looks sporty as hell. You have to make sure you are in the right field of SDS and make sure to save settings. I also added a washer on either side to give the front a .000025 lower stance then the rear. GL!
Reply 0
Sep 14, 2010 | 07:23 PM
LOL Bob Hodges, your funny dude...but if you didnt read I did this exact settings in the SDS field and saved the settings...i put the car in sports 2 setting and went out to ride came back and the car was the same height it was originally...i never saw it going down while i was doing it either...what did i do wrong i dunno thats why im trying to reach out to you guys for...thanks in advanced you sarcastic maniac lol
Reply 0
Sep 14, 2010 | 08:28 PM
Quote: LOL Bob Hodges, your funny dude...but if you didnt read I did this exact settings in the SDS field and saved the settings...i put the car in sports 2 setting and went out to ride came back and the car was the same height it was originally...i never saw it going down while i was doing it either...what did i do wrong i dunno thats why im trying to reach out to you guys for...thanks in advanced you sarcastic maniac lol
you should have seen the car moving as you were adjusting settings. Do it again, and go through the tutorial very closely.
Reply 0
Sep 14, 2010 | 09:23 PM
Follow the tutorial carefully. You are adjusting voltages not ride height. If you don't see it lowering in "real time" you are in the wrong place. You can only lower a little bit as you have to stay in the ranges for the voltage. Go all the way around ONE CLICK, measure and repeat until you are at the very bottom of the ranges. Use a tape measure to make sure you are even and are not leaning. I measured 25 inches from the ground to the highest point of the fender and I think it looks great. Hope it helps. Just remember, the car will lower as you lower the voltage, also make sure to save the settings.
Reply 0
Sep 14, 2010 | 10:24 PM
Quote: Follow the tutorial carefully. You are adjusting voltages not ride height. If you don't see it lowering in "real time" you are in the wrong place. You can only lower a little bit as you have to stay in the ranges for the voltage. Go all the way around ONE CLICK, measure and repeat until you are at the very bottom of the ranges. Use a tape measure to make sure you are even and are not leaning. I measured 25 inches from the ground to the highest point of the fender and I think it looks great. Hope it helps. Just remember, the car will lower as you lower the voltage, also make sure to save the settings.
thanks ill try it tomorrow and let you know...
Reply 0
Explore
Subscribe
Currently Active Users (1)
