Question about the supercharger
However, once you load the supercharger on the belt, and hit the freeway (rpm always greater than 1800). Now if you throttle up again, that chirp is not there indicating that the supercharger is already spinning.
I read from other posts regarding positive displacement supercharger and the bypass valves. It turns out our superchargers use a clutch on the snout of ther charger which is activated only at higher load conditions.
So, once the supercharger is engaged, the bearing is always rotating, and the supercharger screw is also rotating at a lower rpm, even though no boost is generated. Do our cars de-clutch the supercharger completely once it has been engaged (except in city traffic), because I never hear the chirp again once it is engaged, and I am on the freeway (no matter how long I just cruise control; however there is a minor perceptible boost lag, which indicates the twin screws very not rotating very fast)? Or once clutched on the freeway, the bearing always rotates at engine speed, and the screws at a much lower rpm (but they still rotate)? Or is there an electronically actuated clutch between the bearing and the twin screw itself, which only leaves the bearing rotate, and the entire supercharger's life itself is preserved?
Sorry for so many questions, but the mechanics for throttle response on our car is very intriguing. Thanks in advance.
On the other hand, perhaps the supercharger is staying engaged but the ECU is playing with the bypass valve and snapping it shut upon hitting the throttle. Maybe a combo of both.
Wish Benz would give us more info sometimes on their design of the ECU and programming. Guess you can't give away trade secrets but sure is frustrating sometimes.
when u dont notice there is a change in car habit and power, that is when the S/C is not engaged. ^_^ the best way to get your answers.
believe me, even without S/C you can drive very fast but you will reach it slower and please dont try full throttle or even half the peddle so u dont harm your car. normal driving u will never notice the S/C is out unless u hit it hard.
The audible chirp in your clutch assembly may be attributed to the older style clutch. Mercedes now puts in a newer unit that makes much less noise upon engagement/disengagement.
It would be handy to know if the bypass valve actuates (opens a bit) when MAP /IAT's are too high at WOT?
Also, I figured a soft switch way to completely disconnect the supercharger on demand from the pulley. You can use it to save life of the supercharger by not constanly churning it at low load.
So suppose you merge on to the highway with force, and your supercharger is on the belt. Now Mercedes will keep doing boost control in order to save MPG but not the supercharger itself. The supercharger keeps running on the belt, but since the air is taken redirected directly from the intake, no boost is generated. This however increases the wear and tear in the supercharger's mechanically lubricated bearings.
I think in order to decrease the variance of the chirps, Mercedes chose to just engage it once under load and keep it engaged till you get down below 9 mph and very little throttle.
So back to the point, to disconnect it manually after a hard pass or merge; leave the throttle, quickly neutral the tranny. Wait for the rpm to drop under 1K. Now without any throttle, put it back in Drive. The supercharger is disengaged and not running on the belt now
. Now, you have to keep the throttle under 20% acceleration gradient, otherwise it will trigger the ECU to engage the charger on the belt again. However, when you accelerate again, and your clutch is the 03-05 design, it will chirp again
.Mercedes used this clutch in old kompressors, then they discontinued it and made the charger fulltime. But they bought it back in the 55k engines. The clutch only disengages when you come back to 0-9 mph speed, and in C32s it is pretty much fulltime.
Anyways, since I have been empirically trying to figure this out for a little while now, I thought I'd share this connundrum with everybody.
. Now, you have to keep the throttle under 20% acceleration gradient, otherwise it will trigger the ECU to engage the charger on the belt again.The blower is def not turning because with my setup its like 5x louder than stock and you can hear it spinning and it sounds sick.
Iv also logged it and temps start to rise fast once its on.if the blower was on all the time our intake temps would be impossible to controll
when I take her out of storage Ill try ro get a video.I remember when I put the intake on and picked up my friend,the first thing he said was damn your super charger sounds awesome
If you want to hear yours just take the whole intake off and drive it for a second up the street with no intake or filters on it at all
In the newer 7 speed transmissions with the double-declutch option, the transmission goes into neutral with with every downshift. When engaging back the torque converter is closely synced with the engine and the vehicle speed when the gear is engaged. Since this is all sensor and computer actuated there is little room for wear and tear in a modern automatic transmission.
However, I would imagine even if the blower is on all the time, it would not create any high intake temperature issues because it will not be operating under load (rather free wheeling) since the throttle body's air flow clutch for intake into the charger would be shut and no boost would be generated. For instance, in the 4 and 6 cylinder (C32) kompressor cars, the supercharger runs eternally on the belt. Once the ECU determines load conditions, the air flow clutch opens and the feeds it through the supercharger; hence generating boost. This is what is mentioned in the document that I attached some quotes back on this thread under Boost Control.pdf.
http://www.youtube.com/watch?v=u5RrTM6ZlUE
There is a huge drag on the car while trying to spin the blower and everytime I let off the throttle and the back on I get the huge shock/serge/belt chirp of the blower engaging,its def not spinning while light driving
Early supercharged 111
engines used an ECM-controlled
clutch to engage the supercharger.
The clutch is activated
for secondary air injection,
and above 2,200 rpm for
boost generation.
Later 111 engines
dispensed with the
clutch, so are
always engaged.
On our cars on a cold start it will spin the blower and in that pdf it says the 111 did too for secondary air injection
It would be crazzy to spin our blades off boost.you would still be spinning the to 20-30,000 rpm and causing drag on the engine that would be over 100 hp(iv read that the tv puts that much drag)on my stock car the clutch was working so smooth that on most times I couldn't tell the sc was on.now with the bigger pulley the drive train shock is there every time I go past 15-20% throttle
