Is it worth getting one step colder plugs with stock engine?
Old Oct 14, 2010 | 03:08 AM
kompressorfed's Avatar
MB
Can I run the NGK LFR7AIX 2309 with no mods. If not which plugs should I be using on stock engine?
Old Oct 14, 2010 | 06:53 AM
slownrusty's Avatar
'06 E55 K2
No do not run 1 step colder with a stock engine...stock\OEM NGKs work brilliantly.
Old Oct 14, 2010 | 06:57 AM
Hammer Down's Avatar
2015 E63S, 2018 E63S
So at what point do you make the switch? After Pulley/ECU, after Headers? after TB & Airbox?
Old Oct 14, 2010 | 09:34 AM
TTMotorsports's Avatar
Former Vendor of MBWorld
Whatever we're tuning!
The rule of thumb that is usually used is for every 75-100chp you add you should go one step colder.
Old Oct 14, 2010 | 11:02 PM
Thx Bruce, I'm going to order some soon
Old Oct 14, 2010 | 11:58 PM
jcjmw's Avatar
2005 E55 Wagon
Sorry for the silly question, but I do not know the answer. Why would you want to run colder spark plugs when you increase the hp of your engine? I always hear to do that but what are the benefits of a colder plug?
Old Oct 15, 2010 | 05:11 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Colder plugs prevent any hot spots on the plug preveneting detonation. May not be happening but its a decent precaution.
That said the Sparkplug heat is dissapated into the head more easily with a cold plug - so you will have a cooler plug but a hotter head (albeit marginally) and with no pointed hot spots.
Old Oct 15, 2010 | 12:35 PM
Great explanation Steve.
A colder plug can reduce EGT's by 100+ degrees too which is the primary reason for using them!
I am a big fan of Denso Iridiums. Which brand are you thinking of ordering Jack?
Old Oct 15, 2010 | 12:44 PM
I'm a big fan of Denso Iridiums. Which brand are you thinking of ordering Jack?
Bruce which one are you talking about?
2004 MERCEDES-BENZ E55 AMG 5.5L (V8) PK16R11 Double Platinum
2004 MERCEDES-BENZ E55 AMG 5.5L (V8) PK16TT Platinum TT
2004 MERCEDES-BENZ E55 AMG 5.5L (V8) SK16R11 Iridium Long Life
I was thinking about the NGK LFR7AIX Iridium IX
Old Oct 15, 2010 | 05:52 PM
A comparable plug for the NGK #7 heat range is a #22 in Denso.
Look at Denso IK22 or IKH22 for a plug comparable to the NGK with a heat range of 7 which will be 2 steps colder than stock.
IK20 or IKH20 are just 1 step colder plugs than stock.
For reference only:
~75-100chp 1 step colder
~125-150+chp 2 steps colder
Old Oct 15, 2010 | 07:24 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
For reference only:
iirc, 6 is stock heat range. don't go by ngk's website if that's where you got that info.
Old Oct 15, 2010 | 07:53 PM
Thanks for chiming in Mikey.
Hammer asked about a colder plug and he referenced the NGK plug with a heat range of 7 and I referenced what Denso recommends compared to other manufacturers heat indexes.
I would try a Denso 20 which is considered a comparable plug to what NGK offers in a 6 heat index.
The amount of misinformation on spark plugs is . I try and reference multiple sources before deciding on what should be considered reliable information/recommendations.
Old Oct 15, 2010 | 08:09 PM
dsc's Avatar
dsc
2004 E55
I thought the LFR7AIX 2309 NGK Iridium IX spark plug was 1 step colder than our OEM plugs. If not, which NGK plugs are?
Old Oct 16, 2010 | 12:08 AM
That's what I thought based on the info I got from this forum
Old Oct 16, 2010 | 12:14 AM
chiromikey's Avatar
you are correct.
