EGT why is lower better?!
Ok so gone with the one step colder plugs and story goes it should reduce EGT by up to 100deg!
What I am wondering is why is this good? If EGT is lower is all the fuel bring burnt? Is it burning faster ?
Che?
Che?
Dirt Scooters
the reason a colder plug will help reduce egt's is because i colder plug has a faster heat transfer to the tip and begins its cooling faster, the more power you add to an engine the higher the cylinder temp gets so by running a colder plug it lowers those temps and makes for better heat transfer accross the combustion chamber. Colder plugs are also much more likely to foul out than a hotter plug so always remember that.
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Detonation will actually cause EGTs to drop. This behavior has fooled a lot of people because they will watch the EGT and think that it is in a low enough range to be safe, the only reason it is low is because the engine is detonating.
The only way you know what is actually happening is to be very familiar with your specific engine EGT readings as calibrations and probe locations vary. If, for example, you normally run 1500 degrees at a given MAP setting and you suddenly see 1125 after picking up a fresh load of fuel you should be alert to possible or incipient detonation.
I've found that the EGT is the best way to detect detonation. A fuel that is detonating will show lower EGT readings than one that is not.
IMO lower EGT's will always be better than hotter at WOT
I would recommend going with new wires and one step colder plugs. I changed both at 50k and couldn't be happier. You track your car often and IMO worth the peace of mind.
BTW...Here's some FAQ's from NGK's website http://www.ngksparkplugs.com/tech_su...x.asp?mode=nml.
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Detonation is caused by excessive heat and/or pressure for the fuel being run. The excessive heat, if that is the case, can be caused by a lean condition. Or, the detonation can be caused by a fuel with too low an octane rating for the amount of heat and/or pressure in the combustion chamber. Low octane fuel burns hotter and has less ability to resist detonation. Octane is, after all, just a measure of a fuels ability to resist detonation.
A lot of modded guys here run NGK iridium LFR7AIX. A one step colder plug will only help your top end if you're detonating.
A further comment about EGT's: As the AFM is leaned, EGT's will rise to a point and then flatten out and with continued leaning of the AFM the EGT's will decrease - - - this is not where you want to be as it is the prelude to catastrophe.
NGK plugs, to the best of my knowledge, still have the widest operating heat range and came standard in the E55 (not Bosch as in most MB's). Unless you are seeing signs of overheating on the plugs I would stay with the standard heat range.
So the answer to the Question "why are lower EGT's better?" is not very clear then???
