How do you take apart door handles ??
Car does have keyless go.
Thx
No. The one you need is BEHIND the main large rubber seal that surrounds the door. Looking at the door handle, trace directly across to the inside of the door. Behind that big rubber seal is a small hole. Recessed about 2" in that hole is a T-20 bolt. I just checked it again myself. You have to pull the rubber seal back a little to expose the hole. Once you remove the bolt-dont drop it....then the handle slides back and out.
No. The one you need is BEHIND the main large rubber seal that surrounds the door. Looking at the door handle, trace directly across to the inside of the door. Behind that big rubber seal is a small hole. Recessed about 2" in that hole is a T-20 bolt. I just checked it again myself. You have to pull the rubber seal back a little to expose the hole. Once you remove the bolt-dont drop it....then the handle slides back and out. About the easiest door handle removal I have come across. Let me know if you need further clarification.
