MIR Track Rental Sat 11/20/10
#101
3-five-five/ TUNDRA/ 07 997 cab
No problem ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Yea the slicks hurt mph and time but they give you better traction and less drivetrain stress. If I run on radials I'd probably break axles left and right. You will be in the tens in no time. That tune you have on the car is too rich and timing is all over the place.
#102
Ahmad,thanks for the invite&was a pleasure to finally meet you in person after all these years![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
Clayton,pleasure meeting you as well and Im very sorry my tires had you limping the rest of the day
. Your car sounds awesome going down the track![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Nice meeting Jim(Raleigh63)&the rest of his entourage![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
I doubt my car would have run in the 11s today,the temps made there way in the upper 50's with negative D/A of -750 when the gates open,dropping to -350 a few hours later....so Im kinda glad I left it in the garage. Had fun on the bikes tho
#103
Super Moderator
Was the only E55 out there today
No 10's for me yet but..
No meth!
60' 1.742
330' 4.744
1/8 7.206 @ 99.82
1000. 9.323
1/4 ET 11.09 @ 127.39
Tx to (class act) Ahmad's skinnies I think I managed a bit more in the MPH department. Also Used his slicks as well and helped the 60' but hurt MPH and couldn't run better than 11.13 with them
they suck ahmad JK
On a side note I officially found out Meth is hurting my afr's which are slightly rich already. I used it only for the burn out on this pass and went right back without meth after seeing the results to see if could get at least a 1.68 60' and kept spinning off the line..
Stay thirsty my friends......![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
No meth!
60' 1.742
330' 4.744
1/8 7.206 @ 99.82
1000. 9.323
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
#104
No meth!
60' 1.742
330' 4.744
1/8 7.206 @ 99.82
1000. 9.323
they suck ahmad JK
No meth!
60' 1.742
330' 4.744
1/8 7.206 @ 99.82
1000. 9.323
I know it was mentioned that your timing tables and AFR's are off but running 11.0's at 127.5 the tune can't be that bad. I believe you're now in the top 10 now of the fastest E55's....
I'm sure there's room for improvement for every tune out there but be careful running it to the ragged edge. Being fast is great but not at the expense of your engine.
Once again nice job Luis and I look forward to reading your 10 second thread...
#105
cornfed gtr and m3
Adam ran an 11.95 at 119mph.
Second fastest e39 m5 out there! He can drive the crap out of that car! ![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
I didn't run anything. Something came up last minute and I wasn't able to make it. Sucks.. really wanted to catch up with Luis and see Ahmad run.
![mercy](https://mbworld.org/forums/images/smilies/mecry.gif)
#108
Specs:
Rial 18X9.5 w/ 265/40/18 Mickey Thompson ET Street drag radials.
Right. So, again, I had issues. My day went like this:
On the maiden voyage of my new Mickey Thompson's, somehow John Force possessed my right foot, and I put on a smoke show for the ages in the burnout box. They were brand new, so you know....., I had to make sure they were broken in. I was in 'dyno mode' and after my burnout, the car went into limp mode. I didn't know it, until I launched the car. Car felt like it was in 3rd gear on the launch and never shifted the entire way down the track.
Anyway, I limped her back to the pits, scanned the car and saw a few faults. I had a TCU fault, and something about improper gear ratio. I cleared the codes, took her out of dyno mode, and tried again.
From here on out, I only scrubbed the tires, no more big burnouts. The car hooked every time, but felt soft on launch. And for the rest of the day, I had a noticeable delay in the 1-2 shift. The car would run out 1st gear, then fall on it's face right before it shifted into 2nd.
I unhooked the battery for an hour, but it didn't help. I talked to Bruce, Marcin and Jeremy about it, but I wasn't really able to give them the data they needed without hooking it to SDS, which I don't have.
So, with that, my best runs were a couple of 11.5x's @121-122.
The car drives 100% normal, other than the WOT 1-2 shift. I'll get it on a SDS and see what's up.
But, the most important thing is the picture of my burnout. Stay tuned for that...
#109
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Nice job Luis! I'm glad to see your beast coming alive...
. Think about how fast that is when compared to most of the E55's out there...it's fast. I would have a very hard time believing you pulled much timing if any on the big end with your trap speeds. All around your car performed like a champion.
There is no doubt in my mind i would have cracked 10's in the morning, but kept spraying meth when in reality the car did not require it due to the much cooler morning temps and DA being negative plus car kept popping out of gear coming off the line in my first two attempts
It is nooooot easy..These might sound like excuses for some but these are the things you gotta learn from your own car to run great times and the only way to learn them as you very well know is making the passes.
Thanks again for the cheering and advise as you know you are every 55k owner inspiration..cant wait to see how your car will do at Famoso
But man those e30 Bimma's where tearing it down!!
#110
Thanks Rob, good meeting you too. Thanks for bringing the DRs down, they worked like a charm.
Specs:
But, the most important thing is the picture of my burnout. Stay tuned for that...![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Specs:
#111
#114
lol.....great pic.
That must have been snapped right at the beginning of it, because the car was completely engulfed, and even filled up the cockpit.
I had the window cracked a tiny bit, before I realized it wasn't rolled all the way up.
show-off, indeed.
show-off, indeed.
#116
Specs:
Specs:
Quoting myself here....
When I spoke to Marcin, he advised me to remove the TCU for a minute or so, then reconnect it. After that, I was to drive for approximately 10 miles for everything to figure itself out. Since I was at the track, with my wife, and the day was nearing an end, I opted not to do this. I was just going to take it to the dealer and get it hooked to SDS, to see what's up.
However, I did disconnect my battery for an hour, and made a few runs after that. The car still stumbled at the WOT 1-2 shift. Well, I did drive the car home (100 miles), sanely, and put her to rest in the garage. Today I drove it to work. And sure enough, the shift problem appears to be gone.
So, it certainly appears that I just needed to reach the ~10 mile mark for things to settle down after I put her in limp mode.
The problem with my test is, 99% of the time when I go WOT in 1st on street tires, I break the tires loose when boost comes on, ESP kicks in, and then the car shifts to second. Does the same thing in second, then chirps them in 3rd on boost.
So this morning, I tried to ease on the throttle, increasing input all the way to the floor, smoothly. I was able to achieve a few non-spinning shifts from 1-2 and it shifted quickly, and smoothly as it should with this TCU.
I really need to bolt the DRs back on and give her a blast to see what happens.
#118
The D/Rs 265/40/18's are 26.34" diameter
Don't know if that's far enough out (1.87%), to trip a code.
It only threw that code, and went into limp mode once. And that was when I did a big burnout in dyno mode. I made 6 or 7 runs after that, using a small burnout, and didn't trip a single code, but still had the funky 1-2 shift, until I reset the battery and drove the car home.
