Will 21" wheels fit in the rear?
Old Oct 27, 2010 | 04:05 PM
Garagisti's Avatar
2005 E55, 1964 Cadillac El Dorado
I have an opportunity to grab a set of 20" & 21" wheels. These came off a CL500. I'm pretty sure the fronts will fit (offset considering), but I'm wondering if the rears are going to fit. Has anybody done this?
Old Oct 27, 2010 | 04:51 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Not sure... But why is there a need for 21s?? 20s are fine for this car.
Old Oct 27, 2010 | 07:34 PM
Forrest Gump 9's Avatar
shrimp boat
I'm sure it'll fit. I've seen W211 with 22" rims before.
Old Oct 27, 2010 | 08:04 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
So lets get this straight; you are looking to put 285/20-21 on the rear if the offset will allow it and you won't wind up with speedo errors. Searching tirerack shows that no such tire size exists in their inventory.
Old Oct 27, 2010 | 08:27 PM
Garagisti's Avatar
Here's the scoop. I'm currently running 20s. However, my rears are bald. I was given a set of Lowenharts, 20s & 21s. Front tires are 245s, so they should fit no problem, the rears are 295/25/21s. Just wondering if they'll fit for the next few weeks while I put some dough away for some new tires for my 20s. I'm only doing this because I can't afford new tires until the middle of next month.
Old Oct 27, 2010 | 10:33 PM
tbone's Avatar
E500 Sport
If you're looking to run temp wheels, why don't you just run the lowenhart 20's in your rear? So you're mismatched for a while...who cares.
Old Oct 27, 2010 | 10:49 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
I can't speak for the offset or width because you haven't mentioned them, but the overall wheel/tire diameter will fit.
Old Oct 28, 2010 | 12:02 PM
threeMBs's Avatar
Only MBs - the best or nothing
Well I think the real question should be: can 295/30-20 fit?
I think the answer is no, and if so neither will 295/25-21.
While diameter of 26.8" is probably the obsolute maximum that can fit, 295 width in that diameter would not. 275 will, 285 maybe, but not 295 IMO.
Old Nov 2, 2010 | 06:55 AM
jbaker1121's Avatar
MB: E55 AMG, CL550, E3004M Cab + other makes :)
do different sets and start telling people you've been drifting
Old Nov 2, 2010 | 07:22 AM
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
I am sure it will not fit without rubbing. Also, your performance is going to be compromised a lot!
Old Nov 2, 2010 | 10:59 AM
beauphus's Avatar
CLS55 & CL CK60
just because it COULD fit doesnt mean you SHOULD do it IMHO...
