My 1/4 Mile ET from tonight
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Since a couple of members wanted 1/4 mile numbers here they are! I will also get dyno numbers for those who don't believe in the 1320.
![](http://img2.imageshack.us/img2/1366/img00413201010292358.jpg)
![](http://img820.imageshack.us/img820/1880/73788155649924476473100.jpg)
Here is my mod list
180mm, H/E, Meziere pump, Stock TB with grinded shaft, modified exhaust manifolds, X pipe and Jerry Tune.
Here is my mod list
E55, Supercharged Z4 (sold)
That's moving for what little major mods you've done. Interesting that you had a better '60 time (almost .1 sec) on run #1 but ended up with a faster time on run #2. Must have been cooler huh? To me this is the biggest arugment for water/meth and/or killerchiller. You were 2mph faster just because (I'm assuming) the engine was cooler.
nice numbers Shardul our cars are almost identical!!!
I ran a 11.477 too lol
edit you ran almost exactly like my run last week!!!
we would be such a drivers race lol
1.722
4.821
7.382
95.39
11.477
121.02
1.722
4.821
7.382
95.39
11.477
121.02
Chevy Camaro
Weather for sharduls run was 500 DA for the first run 0 for the second. Hope to see some faster time Shardul when the mine shaft air comes to Houston -1000 to -2000DA.
PLATINUM SPONSOR
Congrats Shardul! Performed like a true drag racer.. I am sure many would kill to knock off a 11.4 on thier first pass down the 1/4 mile!!! Your car is flying!! Takes off like a raped ape!
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
It sure looks like stock wheels on back.. IF that is stock tires, you are on the door step to 10's with some slicks. this must be with slicks... am I rambling?
a Rivera...via a Custom 24, Strat and Les Paul
GREAT RUNS - AND GREAT 60's![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
If I'm correct - this was you're FIRST TIME at the track with the 55 and you were on STREET TIRES...absolutely amazing - way to drive the ***** out of your car!!!!!!!!!!!!
It's addicting, isn't it
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
Chevy Camaro
