1/4 Mile times and Jerry @ Eurocharged tuned
Old Oct 30, 2010 | 09:11 AM
vietjdmboi's Avatar
'04 E55 AMG
went to HRP last night with a bunch of local members. after seeing shardul running 11.48 i was anxious to see what my car would run. i was able to do 12.3 @116 first run for the night with ESP on. I tried running with ESP off but the tires wouldnt hook for anything. But after losing to a new cts-v, shardul talked me into letting Jerry @ Eurocharged flash my car to see what would happen.
I was able to run 12.2 @117 after the flash. the car felt so much faster up top. the power came on like a freight train. all i needed was a good set of DRs and i would have been able to run high 11's for sure. But the last run for the night i did 12.3 @118.
upon leaving the track, i decided to get on it from a 40mph roll. the car is just NASTY. it feels like an entirely new car. i am glad i listened to shardul and scott. thanks guys
Old Oct 30, 2010 | 09:57 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
awesome, and now the mod bug......lol
Glad you had fun with the car....now get some dr's and learn how to launch the car!
Old Oct 30, 2010 | 10:01 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
nice i am glad you like it, now get those headers on!
p.s. better change you sig cause she not stock anymore
Old Oct 30, 2010 | 10:28 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Very nice first runs! You will be in the 11`s soon!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 30, 2010 | 10:34 AM
vietjdmboi's Avatar
'04 E55 AMG
I forgot to add that all I have is a meziere pump.
Old Oct 30, 2010 | 12:18 PM
LFMBDC's Avatar
'10 Camaro SS, '11 Mustang 5.0, '06 E55, '99 Silverado LS1, '99 Corvette FRC
Very Nice!
Old Oct 30, 2010 | 12:46 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Not trying to drag you down, but I would think your first mod should have been tires, you ran practically the same time., at least within margin Still...your stock time and trap is a good one. Nice run. I'm sure drivability has improved which is difficult to ascertain with the numbers. Now get some more mods and find that CTS-V.
Old Oct 30, 2010 | 01:49 PM
vietjdmboi's Avatar
'04 E55 AMG
i understand tires should have been my first mod. but i went out there with the intentions of just having fun. it is what it is tho. ill be back with tires. i dont plan on modding my car much further then this. just trying to have fun with what i have.
Old Oct 30, 2010 | 01:54 PM
PetroC63's Avatar
2012 CTS-V
Congrats.
Drag radials will get you in the 11's, no doubt.
You get the 60' times in the low 1.8 area and
its 11's for sure.
Old Nov 2, 2010 | 09:33 AM
the head's Avatar
18 Titan XD 13 Cayenne TT 13 BMW HP4
Wow, I was almost out there with my SL last Friday as well but didn't make it so I'm going this Friday. Same mod - Meziere pump (stock one died) only so I'm looking for a baseline for a "working" car. With a dead pump it did 12.9@108 a few weeks ago but with 100 degree lower intake temps it should run better now.
Old Nov 2, 2010 | 10:37 AM
PLATINUM SPONSOR
2003 CL55
Take out all extra weight, keep your gas low (1/4 tank), lower washer fluid, then run front tires to max inflation and set rear tires to 26 PSI.. Make sure you get your tires hot and don`t roll up to the line, until you have smoke coming off them..
__________________
www.ultimatepd.com
Old Nov 3, 2010 | 10:10 AM
E55AMGGG04's Avatar
04 w211 E55
Was your 12.3 @ 116 run stock or with the flash ?
Old Nov 3, 2010 | 10:23 AM
vietjdmboi's Avatar
'04 E55 AMG
12.3 was completely stock besides the mezeire pump. No flash
