19s Stance/Height
There isn't a difference in appearance in going from 18 to 19s in regards to the gap from the tire to the fender.
I've seen cars where the larger size wheel would make that gap appear enormous. Not the case with the E55.
Another question(s), has your ride feel change at all with 19s? Also, what size tires are you running front and back, and what type and size do you recommend for the most comfortable/softest drive?
Thanks again.
If you're really focused on comfort over performance - get a set of Conti Extreme Contact DWS in the sizes that Tal listed - They have AMAZING dry grip for a high performance all season tire and the side walls are softer so you get a more compliant ride...
Tal - I've fought the lowering bug because I didn't want to sacrifice too much comfort but you just said the magic words (IMPROVED HANDLING). Guess my winter "to do" list is getting longer
In sport II the tire was just about gone into fender well... No rubbing at all
HRE 840R 245/30/20 - 285/25/20
