pulley confusion???do I need 3 or 1?
Old Nov 4, 2010 | 10:20 PM
ertech's Avatar
mercedes 71 280sl. Porsche 930 . Ducati mh900 and ps1000
Hi Guys .I am a little confused , do I need 3 pulleys or jus the crank puley?
can I run a 172 with no tune? if so where is the cheapest place to purchase one?
Thnaks
ps: will post a pic as soon as I get the car.
Old Nov 4, 2010 | 11:54 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
The larger crank pulleys come with a water pump pulley for fitment issues. So if someone advertises a crank pulley, ensure it comes with the WP pulley. Depending on size, you may also need another belt.
No tune is required though highly recommended, now who does that tune..................oh boy.....just search and read, no need to bring that up in another thread. There are countless threads on pulleys and tunes that will keep you busy for a long time.
Old Nov 5, 2010 | 10:30 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
please get a tune
Old Nov 5, 2010 | 10:40 AM
grantwoodtx's Avatar
GLE 63S
My 172mm came with a smaller water pump pulley. As far as cheap is concerned please be very careful with that one. I bought my first pulley used from a forum member and that ended up being a bad idea. As Shardul says get a tune at the same time.
BUT my 2 cents of advice is whoever does the pulley should have some experience with this work. While it not difficult many have have not gotten the torque specs right and as a result the crank pulley backs out and the pulley usually walks itself off the end of the crank. This most times casues keyway damage and an EXPENSIVE fix!
Check out for a pulley and tune combo https://mbworld.org/forums/w211-amg/...bo-1299-a.html
Old Nov 5, 2010 | 10:42 AM
skratch77's Avatar
2005 E55
How much are you looking to spend?
