Thanksgiving holiday clearance
Old Nov 19, 2010 | 03:42 PM
Staff@RPM's Avatar
Former Vendor of MBWorld
Quaife LSD's-
Qdf9V- $950
Motul 5w/40 synthetic oil-
quart- $6.25
Stainless steel brake lines-
set of 4- $120.00
Motive Power bleeder-
$45.00
Meziere water pumps-
$200
4 wheel Alignment Specials-
$126.00 till December 1
Full synthetic oil changes-
-Starting at $120 for most Mercedes Benz
Absorber-
-$9.00
Red light camera license plate spray-
-$20.00
Active Autowerke BMW flashes-
-10% off
Dual Phase Lug Bolts-
-$275.00 until Christmas
Old Nov 19, 2010 | 08:52 PM
Bramage's Avatar
F-250
Thanks for the lugs! They are perfect. Both sets fit the wheels as discussed!
Old Nov 20, 2010 | 11:09 AM
Staff@RPM's Avatar
I'm glad you like them, if you need anything else don't hesitate to get in touch, even if I can't get it for you I will try and steer you in the right direction.
Old Nov 20, 2010 | 11:11 AM
PGT's Avatar
PGT
2014 E550 4Matic with P1/LED/Pano
what does the Quaife fit? Interested in something for my 2010 C207/E550 Coupe
Old Nov 26, 2010 | 10:54 AM
Edmonton's Avatar
E550
Will Quaife ATB QDF9V fit on E550 coupe c207? I read somewhere this part also fit on c63 AMG can you please confirm?
I know the E550 coupe shares the same diff with sedan, which is w212.
Old Dec 1, 2010 | 01:06 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
Sorry for showing up late but the drive home was nice
The car did not pull at all to the right and no more of that grinding sound from the tires.
The best wheel Alignment equipment I have seen so far...
Will be in touch....
Anyone in NYC go have your car align, I am sure you and your car will be happy after it completed.
Imports Hall ***...
Old Dec 1, 2010 | 04:44 PM
Staff@RPM's Avatar
Thank you and it was a pleasure meeting you. We spent quite a lot of money on our alignment machine and it has really proven to be a great asset to our shop and our customers. If anyone is in need of an alignment we will be happy to set you up with an appointment.
-craig
Old Mar 4, 2011 | 11:49 PM
PGT's Avatar
PGT
Old Mar 5, 2011 | 12:09 AM
03'55AMG's Avatar
AMG
im assuming the water pump is also known as the IC pump? if so, are they still available?
Old Mar 5, 2011 | 10:35 AM
Evolved8's Avatar
AMG Fam
Any LSDs left?? PM me
Old Mar 5, 2011 | 02:52 PM
Staff@RPM's Avatar
Let me see if I can find out for you.
I have one Meziere pump left at that price.
I have plenty of LSD's still available right now for any of you guys that want one.
Old Mar 5, 2011 | 03:08 PM
Staff@RPM's Avatar
It sounds like the Quaife will fit your car. If you want I would be willing to take it back if there is a problem with it fitting. You can see if it is the right one without getting to far into the install. Once you have the rear end cover off you will need to count the number of bolts that hold the ring gear onto the LSD and make sure that they are the same number. I got a confirmation that it will fit though.
If you want one let me know. I can have it to you quickly.
