DIY on grille removal?
Old Nov 23, 2010 | 10:11 AM
ELITE_KOV's Avatar
06 E55 / 13 C63
I read the DIY thread and nothing there on how to do this.
I heard this can be a PITA. Just wondering if anyone has written a DIY or basic instructions on how to remove our grille. This is for the E55.
Old Nov 23, 2010 | 10:17 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
If you are talking about the main grill, my 6 year old could do it. It is like 6 bolts and its off. I dont think threre need to be a DIY for grill removal. Have you opened the hood and looked at it?
Old Nov 23, 2010 | 11:00 AM
jpohl402's Avatar
E55 then E63, now back to an E55
No kidding.
We must be doing brain surgery here, lol.
Old Nov 23, 2010 | 11:44 AM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
You should be ashamed of yourself----insulting a 6 year old. If the poster can't figure it out, his car should be taken from him.
Old Nov 23, 2010 | 11:53 AM
lkirchner's Avatar
Old Nov 23, 2010 | 12:56 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Grill comes right out as others have stated. Now, if you plan on painting it, things get more difficult as the grill should be separated. Easy to do, just time consuming.
Old Nov 23, 2010 | 01:08 PM
ELITE_KOV's Avatar
06 E55 / 13 C63
Yes, this is what I meant; I already have the grille out, just wasn't sure if it needs to be separated or if it can be painted as is after grinded down.
How does it separate?
Old Nov 23, 2010 | 01:12 PM
pearlpower's Avatar
You want to do it right and separate the pieces. I used a couple of flat heads to do this. Also remove the lower rubber pads so they do not get painted. It is much easier this way and you ensure the entire assembly gets painted.
Old Nov 23, 2010 | 01:46 PM
emoving's Avatar
Sorry, Thought you meant take it off the hood! I was like WTF!
Old Nov 23, 2010 | 01:56 PM
ELITE_KOV's Avatar
06 E55 / 13 C63
Haha! Oh come on, I'm a little mechanically inclined
Having said that, I can see that separating the grille is going to take some time...looks like a b!tch!
Old Nov 23, 2010 | 01:58 PM
emoving's Avatar
I just painted mine as a whole.
Old Nov 23, 2010 | 02:01 PM
ELITE_KOV's Avatar
06 E55 / 13 C63
Yes, I'm thinking I can paint this as a whole assembly together. Also, I am NOT doing the painting myself, but my good friend of mine has his own custom paint business and he will be doing all the professional painting work.
I think I am just going to let him have at it as it sits right now as an assembly.
Old Nov 23, 2010 | 02:02 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Same..
Old Nov 23, 2010 | 02:12 PM
ELITE_KOV's Avatar
06 E55 / 13 C63
What steps did you guys go through?
Grind, prime, how many layers of paint, then clear coat?
Old Nov 23, 2010 | 03:42 PM
pearlpower's Avatar
It take no more than 10 minutes to separate the grille starting on one end and just working around.
I stripped the chrome off (A *****, though it does peel off), filled in any issues, primer, 3 coats, and clear. I used trim paint initially over the entire grill and it did not hold up (150mph behind a Z06 and he went over sand which took the paint almost all off the grill). I went with Rustoleum and it is holding up very well.
