Meisterschaft mufflers.....aside from the nice sound, is there anthing to gain?
CLS55
I've been on the fence on getting a set of Meisterschafts (used of course) for my ride but other than the bad @ss sound, is there anything gained power or flow wise from having these mufflers?
2005 Flint Grey E55
^^ What if you replace it with a X-pipe? Will you still lose the torque?
That's what I did and I feel like I lost a substantial amount of low-end torque. But it pulls in the high end.
Def don't lose any power from resonators.
Maybe Cats.
Maybe Cats.
2005 Flint Grey E55
What size pipes would you suggest? Thinking about picking up some eisenmann or meisterschaft. Right now I got some Borla mufflers with a 2nd cat delete and resonator delete. The mufflers sound killer, but I feel like it's generating too much heat back to the engine.
1 Post
His wife crazy
I would recommend 3" max. I have a custom X pipe close to where the original crossover was, secondary cats and res delete. I don't think I lost any torque with my setup. I actually spend more time driving in C mode now.
CLS55
Can anyone list pros and cons if adding these Meistershcaft mufflers with an x-pipe, h-pipe or straight pipes along with both cats and resonator delete? I would think there would be power to be gained if adding these mufflers. Would they be loud? Any droneing? I found a used set and was debating on whether I should get them or not.
