stock h/e + secondery h/e
Old Dec 26, 2010 | 07:23 PM
SuperchargerV8's Avatar
03 e55 amg
Who here is running the stock H/E with a secondery H/E in front of it
Also what size secondery h/e is it ?
Old Dec 26, 2010 | 07:31 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
i am, it was custom made by active autowerks
https://mbworld.org/forums/w211-amg/...done-pics.html
Old Dec 26, 2010 | 07:53 PM
LEX99FRC's Avatar
e46 m3
wouldnt it be better to use one bigger one?
Old Dec 26, 2010 | 07:55 PM
Zmydust's Avatar
996 Guards red / 2008 Hayabusa / 2004 E55 AMG
That will be a matter of opinion until someone does a back to back unbiased test, but two given the amount of surface area you would gain would reason to be the better idea with the limited frontal space of the E55.
Old Dec 26, 2010 | 08:27 PM
shardul's Avatar
i have compared my IATS with other local member who run one big unit and mine seem to be a bit lower.
Old Dec 27, 2010 | 05:41 AM
03 e55 amg
would the cm30 pump have the power to pump through the stcok and a secondery h/e as large as yours ?
Old Dec 27, 2010 | 08:44 AM
shardul's Avatar
No you will have to run meziere wp136
Old Dec 27, 2010 | 10:34 AM
TopGun32's Avatar
if you need a pump, I have one for sale under the classifieds section. "engine parts'.
$160 shipped. Mezeire pump with 3/4" fittings.
Old Dec 27, 2010 | 09:02 PM
03 e55 amg
I have 03 E55K so i have heard. I can run a larger h/e then later model E55 is it a 7inch or 7.5inch tall h/e i can use ?
Old Dec 27, 2010 | 09:46 PM
shardul's Avatar
03 dont have the additional oil cooler on the bottom of the stock h/e so yes you can run a slightly bigger one. Problem is that all ones for sale are made to fit 04 and up and they can be also used on the 03. Unless you get a custom one made you will have the regular aftermarket h/e
Old Dec 28, 2010 | 02:18 AM
theeddie's Avatar
e55 w/LET TUNE Drinks: vodka STRAIGHT Wheels: 19" HRE 547r Mods:FF headers ASP Pulley
i want someone to build an aftermark that is x2 or x3 deeper then the stock on
Old Dec 28, 2010 | 02:50 AM
03 e55 amg
yes i am thinking of getting a new one made. but how tall can i fit 7 or 7.5inch does any one remeber how tall the old code 3 h/e's where
They will also ask me what size the entry and exit size should be what size are the stock entry and exit pipes that i will clamp the hoses 2 ?
