Climate Control Question.
Old Dec 27, 2010 | 12:32 AM
06MKV's Avatar
05 E55, 04 Dodge Ram
Hi everyone.
Here is what I am experiencing on my 05 E55.
The drivers side air temp and passenger air temp are the same regardless of the temp indication. For example, if the drivers side is set to 65 and the passanger is set at 80. The temp of the air coming out is the same, around 65. But here is the kicker. If I raise the passenger temp to the highest setting, it will start to blow hot air and the driver side will stay at 65.
I am assuming this is not normal. Any ideas?
Mike
Old Dec 28, 2010 | 06:40 AM
tscales's Avatar
2005 E55 Wagon, 2017 C63S Cab, 1986 560SL
I've found that the climate control just can't handle BIG differences. 65 and 70, yes. 65 and 80, no.
Old Dec 28, 2010 | 10:56 AM
bobgodd's Avatar
2004 E55
I've found that the best way to keep me cool while keeping her warm is to turn her seat heater on, and close all of the vents on her side. I put the a/c on very low, turn my seat fan on, and that usually works.
Old Dec 28, 2010 | 11:00 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
I think you are in a 4 door medium sized car and the two sided climate control is a stupid joke anyways. Maybe put a rubber curtian down the middle of the car and it will work! LOL
Old Dec 28, 2010 | 01:07 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Originally Posted by emoving
I think you are in a 4 door medium sized car and the two sided climate control is a stupid joke anyways. LOL
I know. I think the 4 zone is really crazy. I wonder if I put them to their limits I could creat rain!
Old Dec 28, 2010 | 04:08 PM
ohlord's Avatar
Run the diagnostics
if your ac system has that feature.
Temps should closely match settings.If it gets warm when set to high your duo valve is likely stuck on that side.
Give it a tap with the handle of a screwdriver not a denting blow just a firm tap. That often frees up a stuck valve.
Old Dec 28, 2010 | 11:08 PM
06MKV's Avatar
Thanks for the advise. Where is the Duo valve located? Is it in the cabin?
Thanks!
