Quote:
maybe this will helpOriginally Posted by GT-ER
Maybe you can explain what the problem is?
dont even get me started how the pipes didnt come with the flanges welded on OR CUT
How are the pipes supposed to be connected if there are no flanges? Also, you do not think they will line up when installed? I am thinking it looks like that because it is on the ground...
Quote:
i honestly dont know how they will clear. im very afraid to mock up the headersOriginally Posted by mikey33
this might help
it may work, i guess all i can do is try
Max.H
close
- Join DateNov 2007
- LocationSan Diego
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveE55
Liked:39 Times in 38 Posts
Quote:
Excuse my ignorance. But, I don't see any flanges for the exhaust pipes. My question is how are you suppose to attach the pipes without flanges? Do you grind off the coating and weld them on? Am I missing something? Originally Posted by theeddie
Quote:
There are 4 loose flanges that needs to be welded on. I wish at least one side would of been welded already. I must say the welds and the finish does look really good.Originally Posted by Max.H
Quote:
Okay that makes more sense now, it comes with 4 loose flanges that we need to have welded on ourselves. That definitely would have been odd if he just sent the pipes with no way of connecting them. Originally Posted by E55amg/FD3S
Quote:
i still dont understand why they didnt come with flanges on both sides Originally Posted by mikey33
Okay that makes more sense now, it comes with 4 loose flanges that we need to have welded on ourselves. That definitely would have been odd if he just sent the pipes with no way of connecting them. then we could of just cut the mufflers and put a slip or welded a flange.
they didnt even drill the o2 bungs
ExploreSuper Member
Quote:
this might help
i honestly dont know how they will clear. im very afraid to mock up the headersthis might help
Looks like once you put the rest of the exhaust on they may not clear.
Quote:
this is what i was sold Originally Posted by dacls63amg
i know these headers fit correctly and unless chris somehow shipped the wrong parts, i'd be willing to bet you don't have the parts aligned appropriately. there are left and right sided parts that also have a front-to-back and top/bottom orientation. if they're not properly placed the flanges will push the parts off alignment. the parts should have markings so double check those...
unpacked and i already have a problem
^^^ That is exactly what I was trying to say! I am sure they fit no problems.
All the flanges are labled, Read the directions you cant swap them out or they will not fit. Each part is marked drivers/Pass/Top/Bottom. My system fit, so will yours they came off the same jig
Quote:
i did align with the markingsOriginally Posted by Evolved8
Quote:
do you mind telling me what you are paying? Originally Posted by Hotrodizz
Mine just came in, and are going in the car as we speak.
i got quoted 13 hours!!!
Goodness, it is a four or five hour job.Originally Posted by theeddie
do you mind telling me what you are paying? i got quoted 13 hours!!!
Quote:
thats what i told them!!Originally Posted by I Like Soup
Quote:
Post some pic and feedback. Originally Posted by Hotrodizz
Former Vendor of MBWorld
shardul
close
- Join DateMay 2008
- LocationHouston
iTrader Positive Feedback100
iTrader Feedback Score(1)
- Vehicle(s) I drive2003 W211 E55, 2003 W220 S600
Liked:295 Times in 244 Posts
it takes me 45 mins to remove the stock headers and exhaust.
Quote:
+1Originally Posted by shardul
what is the primary sizing, collector sizing and mid pipe sizing on these kits?
found a place to install mine $400 ouch
but i had to pay for all the extra welding FF forgot to do
Quote:
You must be dropping the entire exhaust as a single assembly (with someone's help). Plus, you must have really small hands and arms to do all of the fasteners on both manifolds that quickly. I salute you Originally Posted by shardul
; it took me way more time than that when I installed my Evosport shorties.Former Vendor of MBWorld
shardul
close
- Join DateMay 2008
- LocationHouston
how does the car feel?Originally Posted by theeddie
found a place to install mine $400 ouchbut i had to pay for all the extra welding FF forgot to do
